#46438 10/23/01 06:26 PM
Rob R. Offline OP
Can anyone tell me if there are is an O2 or any other sensor attached to an MTX on a 95/2.5 litre. I'm trying to trouble shoot a bad throttle hang problem. I just had tranni work done and it does not seem to be a problem with vacuum lines or the O2 sensor(attached at manifold). I am running out of things to check.
Rob
95 Contour LX
Approximately 120,000miles
2.5 MTX
Red
#46439 10/23/01 07:19 PM
O2 sensor attached to the transmission?
They are mounted in the exhaust.
Have you tried the "Throttle Hang Fix" located in the FAQ area???
2000 SVT #674 - Check it out!
#46440 10/23/01 08:47 PM
Rob R. Offline OP
Actually, I have never had the throttle hang problem(I am familiar with it). I was not having this problem until after the car was returned to me by the tranni shop. That's why I'm thinking that someone forgot to hook up a vacuum hose or sensor or something....
95 Contour LX
2.5 MTX
Red
#46441 10/25/01 01:41 AM
Rob R. Offline OP
So I removed the EEC memory fuse and the EEC computer fuse. I wanted to run the codes again making sure I was getting the real deal. The only code that comes up now is the "111" code which means system is ok. I'm going to run the codes in a week to see if I get anything else.
I don't understand why I did not have a throttle hang problem before my tranny work was done - the problem is huge now - I put the throttle hang fix into place and it was like night and day, problem instafix. I guess I'll see what happens.
Rob
95 Contour LX
2.5 MTX
Red
