Posts: 2,375 |
I was told by a Duratec engineer that the best thing that we could do for cheap is run a half quart over the full line- that should help- FYI the oil pan in the duratecs is about 3/4 quart too small for the motor because so much oil stays up in the cams area- gets too much air in it and then when you need it its still up there trying to get back to the oil pickup - so run a 1/2 quart high and it should be ok.
Posts: 425 |
Originally posted by Horse: I was told by a Duratec engineer that the best thing that we could do for cheap is run a half quart over the full line- that should help- FYI the oil pan in the duratecs is about 3/4 quart too small for the motor because so much oil stays up in the cams area- gets too much air in it and then when you need it its still up there trying to get back to the oil pickup - so run a 1/2 quart high and it should be ok. Me like what me hear. I've been running six myself, since 6.5qts sounds a little high IMO, but this definitely sounds like a cheap, good precaution for those who like to hang those righthand corners tight!
I heed the call of the curb
Posts: 219 |
I thought overfilling was bad for the engine? Puts too much strain/pressure on it or something. Is this safe to do?
Thanks, - Zack
- Zack
1995 Contour LX 2.5L V6 MTX 150,000 miles and still going strong PIAA 510's (Finally I can see again!)
"It isn't pollution that's harming the environment. It's the impurities in our air and water that are doing it." George W. Bush
Posts: 645 |
Originally posted by Horse: I was told by a Duratec engineer that the best thing that we could do for cheap is run a half quart over the full line- that should help- FYI the oil pan in the duratecs is about 3/4 quart too small for the motor because so much oil stays up in the cams area- gets too much air in it and then when you need it its still up there trying to get back to the oil pickup - so run a 1/2 quart high and it should be ok. I know after I get this sucker fixed I will be over filling the oil 6-6.5 qts. It is an expensive lesson to learn though.
Chad ----------------- http://www.1dzine.com jetski@mindless.com 98.5 SVT ? KKM Tru Rev ? Glasspack instead of resonator ? Dyno Max Super Turbo Muffler w/Brospeed 3.5" Rolled tips ? Brembo/KVR Cross Drilled Cadnium Front Rotors and KVR Carbon Brake Pads ? Blown Engine Replaced @ 41K
Posts: 3,248 |
Good info Horse! Did the engineer have any comment on the crankshaft areating the oil at the 6.5 quart mark - is this likely to happen? Did he have any other comments about this? I have been running 6.0 myself, may have to go to 6.3.
1999 Amazon Green SVT Contour (#554/2760) Stock SVT Duratec V6 with: Intake- K&N filter/75mm MAF meter Exhaust- MSDS Y-pipe/Bassani catback Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter 179.2 FWHP at 6900 RPM
Posts: 645 |
Just wanted to update. Ford has offered to pay for half of the costs so I gave them the go ahead today. Full engine replacement with radiator, waterpump... the works. Not sure if I'll hang on to the car after the work is done, but I guess I have a little time to think about it. Should be back on the road in 3-4 weeks. Thanks everyone for your support.
Posts: 14 |
Mine just went out tonight! How much are they charging you? Will they do that for me?
Posts: 539 |
I just suffered from a blown engine yest. when i went on an on ramp, one i go on all the time at high speeds, the light flicked on real quick. But the engine didnt blow for another 15-20 miles. Now i take this ramp everyday at high speeds oil was fine jsut checked it the day before. now it looks like mud.
jiako|98 svt silver|kkm true rev|18" Enkie RS5 wrapped w/falken GRB FK451 215/40|Mesh grill| Sony headunit|Boston Acoutics (4)5X7|Memphis 1100 amp|(2) JL 12W3|KVR X drilled rotors|35% tint|2.25" True Duals w/ Magnaflows| kkm pedals|LSD|Fidnaza Flywheel|Centerforce Dual Friction Clutch|FMS wires|Konis/Eibach|ESP bushings and Mounts|75MM PRO FLOW|DMD|Aluminum shifter & E-brake handle|SAFC|HID's and a few more cc's 196.1 and 183.4
Posts: 3,237 |
I run 6 qts of oil in my SVT and have taken this one ramp (26mile to M-53, in MI) HEAPS of times at at least 0.8G going right, as fast as I can, with my tires on the limit of adhesion (squealing). No problem as of yet. I think the fact that I have a sway bar (keeps car flatter) and the fact that I run a fulls six quarts in it helps. But who knows?
Posts: 1,444 |
Does anyone have the actual number of contours that have blown their engines?
Last time I tried to figure it out is was around 20 on this board. But I know it's more than that.
If you have a good guess or know that number please post it.
