Posts: 645 |
I had my engine go out this weekend. Right hands sweeper = oil starvation. I dropped it off at the dealership but was unsure what the powertrain warranty is on the contours. I have a 98.5 SVT with 41K on it. Anybody have any idea if I'm cover or screwed. Thanks for any help.
Chad ----------------- http://www.1dzine.com jetski@mindless.com 98.5 SVT ? KKM Tru Rev ? Glasspack instead of resonator ? Dyno Max Super Turbo Muffler w/Brospeed 3.5" Rolled tips ? Brembo/KVR Cross Drilled Cadnium Front Rotors and KVR Carbon Brake Pads ? Blown Engine Replaced @ 41K
Posts: 283 |
After 36k miles, unless you bought an extended service plan, there's not any warranty left except possibly exterior paint and emissions. Doesn't look good.
//> //> //> //> //> Garrick Silver E0, #3895 of 6535, built 10/2/97 She's stock. Why mess with a good thing?
Posts: 645 |
thanks garret, that is what I figured.
Posts: 1,861 |
At 41,000 miles you should not be bashful about asking for factory assistance. Make sure that you talk with the service manager, if needed, not just the service advisor. With a little bit of luck, Ford may pick up most (but not all) of the repair.
Jim Johnson 98 SVT
Posts: 645 |
Originally posted by Big Jim: At 41,000 miles you should not be bashful about asking for factory assistance. Make sure that you talk with the service manager, if needed, not just the service advisor. With a little bit of luck, Ford may pick up most (but not all) of the repair. Thanks for the advice Big Jim. I will address that tomorrow. I have to agree this is a little less than satisfactory on a 3.5 year old car.
