is it possible to blow the left front and the right back @ the same time? are they somehow wired together? does this make sense ? ideas...suggestions..answers...help!!!! 97 lx
Did they just stop working, or do they just sound terrible?
www.ChicagoCEG.com 2006 White Grand Prix
they just stopped working at the same time...but i must admit i had them cranked at the time....
Premium Sound System has an amplifier (behind the glove box). If this is a stock system, maybe the amp went..
My name is Richard. I was a Contouraholic. NOW: '02 Mazda B3000 Dual Sport, Black BEFORE: '99 Contour SE Sport Duratec ATX Spruce Green PIAA 510's, Foglight MOD, K&N Drop-in
how can i tell if it is premium sound or do i jus t look for a amp?
to check if it has a premium sound system jstu remove the carpet piece under the glove box and look up on the fire wall. If you have premium sound the amp should be there.
1998 T-Red SVT (SOLD) #4230 BOD-12/5/97 99 3L and stuff 2003 Jaguar X-Type
thanks....now if the amp is the problem...how do i tell?
N
N
use the output side of the wiring harness going to the speakers, and (of course use a wiring diagram or metra harness #5513) and pop the bad speakers with a 9 volt battery. if they pop, its either the amp, the in dash unit, or the cable. I do have a spare amp and factory cd player that came out of my 98 SE if you are interested. the best way to overcome the problem, is to add an aftermarket deck, and bypass the amp. its not that hard to do. metra makes the harness, and all you have to do is extend the speaker wire from the dash, to the amp harness. what i did when i first got the car.
Happiness is knocking the back end looser than a two-dollar whore.
