#46094 10/18/01 05:06 PM
F
F
As soon as I turn off the car. My antenna won't go down. The motor for the antenna is running, but no movement from the antenna. What should I do?
Chris Reid
99 Black SVT #6330
#46095 10/18/01 05:32 PM
I
I
do you have factory radio? Does it go down when you shut down the radio? Does it ever do down?
Ciao
Forza America!!! CT in the House!!!
98.5 Ford contour SVT
Alpine head unit, mbquart separates up front, 6x9 pioneers in the back. Running 500whats fosgate to two 10 kicker subs at 2ohms. Running 50x4 fosgate to the front and back speakers.
#46096 10/18/01 06:19 PM
Did you check the gearbox in the motor housing?
ITIMIDATOR730@msn.com
98 SE ATX Sport/Black/All badges off/ding guards off/K&N air and oil filter/MAF Mod/polished intake/polished MAF/polished Throttle body/Painted rear reflector and lights w/red cut-outs/PPG badges/straight piped exh./many more.
#46097 10/18/01 06:23 PM
E
E
Is it bent slightly? That can jam it up.
95GL25
#46098 10/19/01 03:03 AM
mine did a similar thing, even did it at the dealership when i was about to buy the car. i asked the sales guy why it wouldn't go down all the way (stayed like a foot up) and he said it's the way the newer antennas are!! i was like you bastrd liar! anyway, if you pull up on the antenna, chances are there's a bend at the bottom that is hidden beneath the fender. mine looked straight when it was up all the way but i pulled up and like 2 inches of antenna came out of the fender and there was a nice bend there.
-Dan
1998.5 SVT "Black and Blue" #5292
See here for MOD list.
"Washing your car to make it rain does not work."
#46099 10/19/01 03:07 AM
V
V
" He said that's the way the newer ones are" That's one of the funniest thing I've ever heard. All car salesmen should wear condoms, cause all they try to do is rape you!!!!!!!
vinny "2000 T-RED SVT"
Mods:
kkm
sho shop off road y-pipe
Audio:
Alpine CDM 7874
Audio Control 4.1 EQ/Line driver
Mb quart rsb 215 comp.
Mb quart rsc 216 comp.
blueprint 1001 sub
2 Phoenix Gold qx2180 amps
#46100 10/19/01 04:54 AM
Most likely the mast has stripped teeth on the plastic "whip" end that scrolls up in the motor. Between a slightly bent mast and slightly worn teeth, either one or both, the teeth don't catch on the mechanism in the motor.
Usually you just need to replace the mast. Part runs about $40.00.
Jim Johnson
98 SVT
#46101 10/19/01 02:42 PM
This is what happened to mine, the last/first 2 inches of the plastic whip actually was broken off inside my antenna motor. I went to the dealership, paid my 40 some odd bucks, took the antenna motor out, opened it up to get the last piece out of the track/guide. I then, put the motor back in the car, and how you put the new antenna back in is you have to turn on the radio, wait for the motor to stop, then put in the plastic whip. (Make sure that when you put in the tail end of the whip, the antenna is fully extended, it makes it easier.) Then turn off the radio, the antenna motor will start to pull on the plastic, and will stop when the antenna is all the way down. You may have to feed the antenna a little, to get it to start going down.
dion
98 SVT with some mods
http://communities.msn.com/contourstuff
#46102 10/29/01 08:53 AM
they seem to stop going down after about 6 years. my friend and i both have 95 mystiques and they both stopped lowering at about the same time.
1995 Mercury Mystique GS
2.0L Zetec, MTX
10% dents all around
its not my fault its teal!!! it was cheap!
