Posts: 9,442 |
You can get them brand new from here
Posts: 3,627 |
i need to get a chip we should get a gb together
Trollin the boards as of 9/23
Originally posted by GS474: stock hp is never enough
Posts: 25 |
i bought a superchip for $190 off a company i found on the net, 190 was the cheapist i could find it, everyone else wanted 200+. You have to make sure to tell them that you want the speed/rev limiter removed on your chip or they wont do it. I really like my superchip(ATX) no complaints here ive taken it up to 127 so far havent got a chance to go higher. You can take it up to redline in your last gear which should be at least 140+
95 contour
2.5
intake,exhaust,removed resmagnecore wires
--Superchip Blue module PEW4--
Battery Relocated
Posts: 115 |
Originally posted by StaticTour96: i need to get a chip we should get a gb together
Sounds like a good idea to me!
98 Black Mystique ATX/Duratec
"Mystique, the luxury SVT"
P.S.- This is what part of the alphabet would look like if the letters Q and R were eliminated....
Posts: 21,653 |
hitman where did u get u'r superchip?
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 13 |
What kind or brand of chip?, because I bought a Superchip and they tried 6 times with different configurations of the program, and just can't get rid of it. Does anyone know if Diablo sport can do the job?
I am Canuckian
I am Canuckian
Posts: 4,168 |
Most Contiques are governed to 112 MPH or 184 KPH. Cougars as I recall have no governor. There are a few eceptions to the rule. SVT's have no governor and a few CEG'er report that they have no governor. Yes with a chip you can bypass it without compromising your instrumentation. It is stupid and fool hardy to exceed the speed rating of your tires. So if you do get your governor bypassed protect yourself with a good set of rubbers. To address the speed that the vehicle can obtain is another story. This falls based on how much HP you are pushing. SVT's can do a reported top speed of 140+ MPH. I you modify your vehicle this can be bettered or comprimised. A regular V6 can reach 125+MPH. Of course this to can be bettered or worsened with mods. The ATX has a larger final gear than the MTX and some misconstue this to mean it will go faster. Truth is this is false. Again you can only go as fast as HP or drag will allow. On another note on my first high speed run when I ran into the governor I made a mistake. Not at the time knowing at what point the governor was set up at and running out of safe stopping distance. I clutched in only to stall the engine @ aprox 185kph. When the governor kicks on it retards the fuel supply. I time this perfectly to screw myself. No engine power = no power brakes or steering. I almost made poopie of myself. I slowed down as needed but not without a near heart attack. Point of the story running out to top speed is stupid. Not saying I won't ever do it again. Just wanting to make sure no one has the same situation arise. Cheers
Green 96 mystique gs 4cyl mtx
16.9 in the 1/4 mile @102500 miles
95SE in Midnight Red MTX
MSDS headers and y-pipe
SVT exhaust
SVT UIM
Optimized se TB.
Full pre 98 SVT body kit
15.741 @ 87.73mph :)
Posts: 13 |
Wow! what a story! :drool: thanks for the advise, actually I'm about to purchase Wilwood brake set, because I also feel the OEM are not enough! :shocked:
Regards David
Posts: 1,977 |
Originally posted by mbb41: On another note on my first high speed run when I ran into the governor I made a mistake. Not at the time knowing at what point the governor was set up at and running out of safe stopping distance. I clutched in only to stall the engine @ aprox 185kph. When the governor kicks on it retards the fuel supply. I time this perfectly to screw myself. No engine power = no power brakes or steering. I almost made poopie of myself. I slowed down as needed but not without a near heart attack.
Why the hell would you clutch in at that speed? During high speed runs, I always brake first, then if the rpm gets too low I put in the clutch. BTW, even if the engine is off you'll still have a pump or two left in the brake that's power assisted. That's because the brake booster is still basically a vacuum.
Posts: 320 |
Just as a note:
FOr those who want more power and remove their limiter on their 98+ contiques for less $$ than a chip, you can have your PCM reprogrammed to SVT calibration at your local dealer. I had mine done, and it works.
