Posts: 1,516 |
Originally posted by SonOfABoss: Take the new 02 sensor back out and check it, you may have messed something up... Switch to 89 or 87 oct gas, that will improve gas mileage also... I noticed a 2 mpg gain just from switching from 93 oct to 89 oct... Replace the plugs,wires, and fuel filter... If that still doesn't help, there's one more thing you can replace.......the car
Sure you ain't got that backwards? I get GREAT gas milage when I run premium (93 octain) about 22.5 mpg compaired to reg gas at ~19mpg all in town!
Mazda 6S, V6, Speed Yellow
5 Speed, Sport package
Bose audio
Painted 'stash and HIDs!
w/Injen 1/4 14.750 @ 94.94
Former car:
99 Contour SE Sport Black MTX V6
SVT plastic...
1/4 - 15.012 @ 90.58
Posts: 23 |
I changed my plugs and wires and I got 25 more miles per tank. I'm running a completely stock vehicle and getting anywhere from 320-375 miles per tank on 89 octane. That mileage is a mix of city/highway and the occasional pedal-to the metal.
Posts: 391 |
I get about 280-300 in town, that is also with a couple pedal to the metals,  and havn't really been highway driving in her yet but I plan on going to Fargo and back in a couple weeks, bout 290 miles away. Also our engines are designed for 87 octane fuel, which is why you should get better gas milage that way, 92 or 93 octane is harder for the engine to burn.
Alan
93 Acura Integra LS 5spd
Horizon Gray Metallic
-96 Gl Zetec ATX- Totaled as of 11/29/03 at 4pm
Champagne Metallic CC
Pics
Posts: 1,580 |
Your Zetec might be, but the Duratec in the SVT is designed for the higher burn rate 93 octane.
** Mike **
"You might beat me in a straight line, but I'll embarass you in the turns"
Posts: 391 |
Well yeah, the but the other duratechs should be designed to the same parameters. The svt was made to be a little bit more high performance than our little zetecs and non-svt duratechs, This is what I have been told anyway. my .02
Alan
Pics
Posts: 203 |
I'm sure I got it right, I may even go to 87 just too see if that helps any...
~*TJ*~ 97 GL Sport Zetec MTX
~*RIP*~ Connie~*1/21/02*
Sold the Zetec, now the prouud owner of an 01 VW GTi VR6 - Sold the GTI now have 97 Mustang Cobra
Posts: 212 |
Originally posted by PoopStainz: i fill my tank up, and run it to E, and egt about 160-180 miles. i even try not to be heavy on the pedal. its a duratec, 97. i just recently put in a new 02 sensor, could that be the problem?
BRO, YOUR MY HERO... I LOVE YOUR NAME
1995 Ford Mustang GT
Magnaflow Exaust
Clear Corners
BBK Cold Air Intake
MSD Ignition
Alpine Security System
2 12' Alpine Type S Subs in Alpine Box
Sony 1100W Mono Amp
JVC CD/WMA/MP3 Deck
Sold!!!
1996 Ford Contour GL
Posts: 263 |
I only drive on 87 and get 280miles on a tank City Driving. It is an MTX (not automatic) and i don't drive it hard.
1996SE sports package, Duratec MTX No mods yet.
80K Kilometers.
Wife has 1996GL Zetec ATX.
Posts: 27 |
Plugs, wires, and gas/air filter are all good sugestions. I have heard that the intake manifold often leaks between upper and lower halves and around the throttle body. While idling, spray some carb cleaner around these "joints" and see if you get any idle speed "flares".
Also, find an AutoZone store and have them "pull the codes" (around here its's a "no charge") to see if there is anything else wrong.
Posts: 3,732 |
Russell
Oval Port 3L Nearly Done
