morten Offline OP
The squeak just won't go away in my 99 CSVT. I've greased everything, including the bar under the car as per the FAQ. Nothin'.
I tried some tricks with my seats (putting some cloth under then to force then a bit higher and tighter). That helped for a bit. But now it's back. And, I greased the hell out of the brake line clip. Nothin'. It definately seems to be coming from the rear seat area. Happens over bumps. It really is driving me nuts. Any ideas - please?
99 Black/Tan CSVT # 1070 of 2760 Stock with K&N Drop in
Sorry buddy I'm out of Ideas.
99 CSVT Green/Tan # 84 of 2760 Built on Wednesday, September 30, 1998 15.376 @ 92.00 MPH Stock 75,000Km 96 Contour GL 2.5L V6 ATX 170,000Km
How about if you take the seat out, and then drive it? This should tell you if it is or is not associated with the seat.
morten Offline OP
not a bad idea. Thanks. How do I take the seat out? Are there clips or levers?
same boat with my 99 csvt...squeaks like crazy in the rear ..pm me if you solve it, please!!!
#1000 of 2760 Money talks, it says good-bye!!! 19's are here...
1
i have the same problem in my pre 98 its the clips in the seat
1999 SVT black And a Blond Haired Blue eyes girlfriend. How can it get any better?
I've found that if you pop the rear seats (pull the lever in the trunk) many noises go away. Maybe you could try that.
1999 Contour SVT #1966/2760, Silver Frost/Midnight Blue Koni Kit, Mille Miglia MM-S rims, B&M shifter, Stazi mesh, SFCs, optimized Y-pipe & TB, SS break lines, K&N drop-in, Infinity Kappa speakers, MTX amp/sub
Me too anybody have more ideas. How you take the seat out?
the rats are on the cheetos again Jet mechanic 98 silver frost SVT DMD Modified Intake First SVT to see the world Keenwood 10CD CHANGER, 12" JBL,4 CV
H
H
To remove the rear seat cushion.
1 Push the cushion towards the backrest to disengage the retaining clips.
2 Lift the cushion up to remove.
I had the same problem, the pahelstic clip that hold the seat down were the culprit. It's impossible to get them out w/o breaking them although i have tried to remove the seat by pushing it back first.
'99 Black/Tan SVT #291 of 2760 Tinted Mirko Splitter Pioneer 8400MP & 3-way 6x8's Clear corners Custom SVT banner A-Pillar pod with Volt, Oil Temp & Press. gauges B&M Diamond Blue Fogs White HVAC the99svttour@yahoo.com
