Posts: 171 |
The squeak just won't go away in my 99 CSVT. I've greased everything, including the bar under the car as per the FAQ. Nothin'.
I tried some tricks with my seats (putting some cloth under then to force then a bit higher and tighter). That helped for a bit. But now it's back. And, I greased the hell out of the brake line clip. Nothin'. It definately seems to be coming from the rear seat area. Happens over bumps. It really is driving me nuts. Any ideas - please?
99 Black/Tan CSVT
# 1070 of 2760
Stock with K&N Drop in
Posts: 2,807 |
Sorry buddy I'm out of Ideas.
99 CSVT Green/Tan
# 84 of 2760
15.376 @ 92.00 MPH Stock
75,000Km
96 Contour GL
2.5L V6 ATX 170,000Km
Posts: 1,459 |
How about if you take the seat out, and then drive it? This should tell you if it is or is not associated with the seat.
95 Mystique Zetec, MTX
2000 Taurus SEL 3.0L Duratec
1994 Crown Victoria LX 4.6 V8
1993 Chevy Silverado 4.3 V6
Posts: 171 |
not a bad idea. Thanks. How do I take the seat out? Are there clips or levers?
99 Black/Tan CSVT
# 1070 of 2760
Posts: 202 |
same boat with my 99 csvt...squeaks like crazy in the rear  ..pm me if you solve it, please!!!
#1000 of 2760
Money talks, it says good-bye!!!
19's are here...
Posts: 1,249 |
i have the same problem in my pre 98 its the clips in the seat
1999 SVT black
And a Blond Haired Blue eyes girlfriend. How can it get any better?
Posts: 499 |
I've found that if you pop the rear seats (pull the lever in the trunk) many noises go away. Maybe you could try that.
1999 Contour SVT #1966/2760, Silver Frost/Midnight Blue
Koni Kit, Mille Miglia MM-S rims, B&M shifter, Stazi mesh, SFCs, optimized Y-pipe & TB, SS break lines, K&N drop-in, Infinity Kappa speakers, MTX amp/sub
Posts: 94 |
Me too anybody have more ideas. How you take the seat out?
the rats are on the cheetos again
Jet mechanic
98 silver frost SVT
DMD
Modified Intake
First SVT to see the world
Keenwood 10CD CHANGER, 12" JBL,4 CV
Posts: 2,319 |
To remove the rear seat cushion. 1 Push the cushion towards the backrest to disengage the retaining clips. 2 Lift the cushion up to remove.
Posts: 285 |
I had the same problem, the pahelstic clip that hold the seat down were the culprit. It's impossible to get them out w/o breaking them although i have tried to remove the seat by pushing it back first.
'99 Black/Tan SVT
#291 of 2760
Tinted
Mirko Splitter
Pioneer 8400MP & 3-way 6x8's
Clear corners
Custom SVT banner
A-Pillar pod with Volt, Oil Temp & Press. gauges
B&M
Diamond Blue Fogs
White HVAC
the99svttour@yahoo.com
