Posts: 1,459 |
Originally posted by Kremithefrog: i think low speed works when i turn a/c or something on... but only one fan comes on in normal driving once it gets near hot range (high speed fan),
Do you have the two fan version, or do you have one fan that operates at two speeds?
95 Mystique Zetec, MTX
2000 Taurus SEL 3.0L Duratec
1994 Crown Victoria LX 4.6 V8
1993 Chevy Silverado 4.3 V6
Posts: 21,653 |
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 1,459 |
Me too, and I'm trying to figure out how to tell the difference between low speed and high speed. (I know, one is faster than the other  ), but without a reference point, I don't know how fast is fast and how slow is slow. I only hear one speed, and I think it is fast. On my last trip to the Ford dealer, they removed the resistor in the wiring harness, so I figure I'll only have high speed, no matter which relay is controlling it.I tried switching relays from my contour to my mystique, and vice versa, to check the condition of the relay, but everything is still the same....I guess I'm going to try using a multi-meter to see where the current is coming from and going to.
Posts: 21,653 |
low speed is a quiet hummmmm, high is a hmmmmmmm without the u. sorta hard to explain, high is a noticeable sound.
98.5 SVT
Posts: 89 |
Re the two-speed fan setup; High speed is definitely noticeable from outside the vehicle. I've heard it up to 30 ft. away from the vehicle. You should be able to hear the difference when running ac or defroster. Low speed is barely noticeable.....my $.02
Is the smoke alarm in your house also known as the dinner bell?
'99 Zetec VCT Daily Driver
Mild Air Filter Mod
Posts: 1,459 |
Then mine is definitely high speed. I can hear it from the outside, when I'm several yards away. And, I can hear and feel it when I'm inside the car, if the car is idleing. The sound is the same, whether the fan kicks on because of the a/c being engaged, or whether the fan kicks on because the temperature reaches a high level. This is further evidence that my low speed relay/fan/etc is not working, which explains why the temperature gauge goes to the L in normal before the fan ever kicks in.
