Posts: 955 |
my car for the past 2 weeks has been swallowing gas like crazy. i retanked saturday to 3/4 full and now (tuesday)im at almost 0 its on the red line. what can be the problem. this mourning i had 1/4 left i went to school 10 minutes away, then i get bak hom and its on red. what gives?
Do our cars have a reserve?
Experience is the worst teacher; it gives the test before presenting the lesson. "You peel my onion down to the nun" - Gene Hackman [Under Suspicion] -Walter- 96 Contour LX
Posts: 198 |
When the low fuel light goes on, you're supposed to have approx. 2 gallons left in the tank.
I assume the car is running ok? Check your tire pressure too, as underinflated tires really mess up your MPG.
98.5 Silver Frost SVT #5260 Born on 3/25/98
Posts: 7,329 |
What gas mileage have you been getting?
Posts: 955 |
180 miles on full tank, but thats with heavy acceration.
Posts: 683 |
I've noticed the same thing with my car lately the absolute best I could get was 400km (all highway)on a tank I used to be able to see 550. I got the 2.5 with an auto. I have checked the tire pressure and it's fine on my car and I got a new air filter, fuel filter plugs and wires but Im still not seeing any benefits. any other suggestions
Currently: 2002 ztw focus wagon, black, manual. Yippee it sucks!!
blitzkrieg53@hotmail.com
Posts: 803 |
Originally posted by blitzkrieg53: I've noticed the same thing with my car lately the absolute best I could get was 400km (all highway)on a tank I used to be able to see 550. I got the 2.5 with an auto. I have checked the tire pressure and it's fine on my car and I got a new air filter, fuel filter plugs and wires but Im still not seeing any benefits. any other suggestions There are so many posible reasons but here are a some that I have heard of. pcv valve, caytlitic convertor, and the timing Btw I get 700km's highway on my ztec, but have talked to one 2.5 owner whom says that they were getting 800kms on the highway. As well don't forget that as the weather get colder the milage for all cars in general gets worse. (figure that one out, at the time of the year you want to spend the least time at the pumps.......) I often get my best tanks of gas on the hottest days of the year!!
hunter green 96 mystique mtx, sabb side markers deep tints car bra., K & N filter, hyper white low beams, after market fogs, JVC Kameleon head unit, 600 watt amp with 2 10" kicker subs, soon to come new rims
New adition 01/11/2002 The original 95SE in Midnight Red all the toys including traction control Fog light mod, lightmoonroof switch from a focus, power antena (still wiring it up) post 98 sail panels, new water pump , Bosch quad plaitnum plugs, and a new Cat.
Posts: 3,567 |
it is possible that you coolant temperature sensor has failed and is sending a signal equivilent to cold, which is casuing the computer to run in warm-up mode in which the fuel mixture is enrichened.
It is also possible that the fuel injectors are dirty and not making the proper spray pattern, that can be fixed by a heavy dose of injector cleaner in the gas.
A restrictive exhaust system will casue fuel consumption to increase due to poor exhasut gas scavenging. check the exhasut pipes to see if they have been kincked, perhaps you backed into something and kinked the tailpipe.
"careful man, there's a beverage here." e-mail: boseraq@hotmail.com aol IM: madhat1412
Posts: 3,419 |
Don' forget the simple stuff: cold ambient causes the tire pressure to drop ~ 1 psi for every 10 degF drop -> lower psi = lower mpg colder air is more dense, therefore the computer adjusts by putting more fuel in the charge -> more fuel per cycle = lower mpg (maybe, not sure, but it also means more HP!) i think these cars run a little rich by default until the car warms up, and when it's cold it takes longer to get to operating temp. They always run a little rich at idle, and the car uses more fuel to idle whan it is cold (see above re: density). that time at 0 mph is a real heavy weight on mpg calcs EDIT: Wow, I'm really the master of what everbody else said. Maybe one day I'll have something original to post.
Posts: 3,567 |
lets not forget that he colder temperatures cause the oil temperature to stabilize at a lower temperature, and we all know how temperature play a part in oil viscosity.
I noticed a 2-3 MPG decrease in my SVT between summer and winter.
Posts: 677 |
Check for: 1. holes 2. Neighbor with a hose.
98.5 SE Sport badgeless, MTX, KKM, SVT exhaust with resonator intact. 1985 Z51 Vette with many mods. Only used when the Tour appears to be outclassed.
