#457537 10/12/02 02:30 PM
N
N
Poking under the hood of the wife's 98 Zetec, there is a hose right next to the battery (looks like a vacuum hose), to the left of it if you are standing in front of the car. I noticed the other end wasn't plugged into anything... so who knows if it somehow came off, or more than likely I pulled it off without knowing it. Can anyone tell me where the other end is suppose to go into? I can't find it at the moment.
TIA
Is it attatched to the battery tray? If so, I have one too, and it's not attatched to anything...I just assumed it was a drain hose or something...
2000 Silver Frost SVT # 1637/2150 D.O.B. 01/14/2000
H
H
Breather/overflow from transmission. Open end should sit on rear bat. hold-down clamp bolt and point down.
You wil have to remove the battery and you will see a side cover on the transaxle , black in colour. T he hose plugs into the top of the cover and the other end sits on the battery hold down bolt. This is the vent tube for the transaxle.
