Page 2 of 2 1 2
#45747 10/14/01 12:31 AM
someone had their TPS replaced at the dealer and it fixed this situation - see the general forum....
Todd Christ SVT Contour Registry
MODS: KKM Intake, SHO Shop Y-Pipe, Bullit Fuel Door, Edelbrock RPM Resonator
'98 E0 SVT Contour #1037 of 6535
#45748 10/15/01 10:23 PM
I would expect a bad TPS to give you dead spots in your accelerations or a constant bad iddle. a surging idle is more likely a vacuum leak or bad iac. I would suspect that if you look right where the vacuum hose connects to the throttle body that you have a crack in the vacuum line.
Page 2 of 2 1 2
