#45653 10/01/01 12:38 AM
I had a plug blow out while driving home from Baltimore today. Anybody have any advise on helicoiling the threads that were stripped out? Should I try this myself or let a professional handle it?
GalaxyEng
95 SE MTX Electric Red
2000 Lightning Red
Yes, I like Red Fords!
#45654 10/01/01 02:41 AM
Well, if you aren't mechanically inclined, I wouldn't suggest doing that sort of thing yourself. I've done quite a few, however, I'm paid to do it. wink
I'ts not that complicated a procedure, but if its improperly done, it can cause more harm than good. That,and you need compressed air to blow out the metal shavings from tapping the cylinder head once you are done. Most people don't have compressors at home.
-Jeff
-"The Crazy Canuck!!"
-"Rice": Anything that looks faster than it really is...
My Ride! http://members.sounddomain.com/sideoftheroad
#45655 10/01/01 03:35 AM
Jeff have you seen the plug holes on the V6...
Good luck getting a tap or heli-coil in there without the proper tools...
Take it to a shop. That way if the screw up and have to pull the head it's not on your dollar...
I've done the old style plug holes (steel & aluminum) on the motor, but would not want to try recessed holes in an aluminum head.
2000 SVT #674 - Check it out!
#45656 10/04/01 11:46 PM
Good advise!
I have a compressor, tools and quite a bit of mechanical knowledge, however, I did not want to tackle this particular project. As a side note, driving home from the repair shop after the repair, the motor rattled and died mad so i think a major cash outlay is close at hand frown On the bright side I just bought a 2001 Corvette Z06 so at least I have an alternate ride laugh laugh
GalaxyEng
2000 Lightning Red
#45657 10/05/01 12:18 AM
E
E
the same thing happened 2 me blew the plug and spun a bearing made alotas noise after the heli-coil so it was new motor time 4 me
97 gsxr lotsa good stuff 4 sale
95 talon tsi awd turbo loaded sold
95 se 2.5 mtx loaded (fragile handle with care)2 motors 3 trannies
custom y with hi flo cat,custom dynomax exhaust,upper cat mod
superchip,udp,bat\kkm,proflow maf,ford 9mm wires,svt throttle body,svt intake manifold ,custom kevlar clutch,16 pd. flywheel,svt motor mounts ,svt gauges,eibachs\h&r,omp strut brace,dark chrome 16" rials with 225/50 dunlops,cwazy amounts of audio
#45658 10/05/01 01:06 PM
E
E
Spark plugs don't rip out all by themselves, some sub-sub-moron has to strip the threads in the head first!! So WHO last changed your plugs? or was it a FACTORY fault?
One beat'99 Tropic Green SVT
#45659 10/05/01 01:24 PM
E
E
it seems 2 happen on our motors and also the big ford diesel and the v 10's also
#45660 10/05/01 01:30 PM
Diesels dont have spark plugs! eek
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
#45661 10/05/01 01:52 PM
Lee Offline
Nope they have glow rods...reminds me of those stupid glow worm dolls...
Lee Cox
In life begins responsability...
Project Car
#45662 10/05/01 01:58 PM
Glow plugs on indirect injection diesels,none on direct injection diesels. wink
V6 MTX
