Posts: 47 |
I had a plug blow out while driving home from Baltimore today. Anybody have any advise on helicoiling the threads that were stripped out? Should I try this myself or let a professional handle it?
GalaxyEng 95 SE MTX Electric Red 2000 Lightning Red Yes, I like Red Fords!
Posts: 860 |
Well, if you aren't mechanically inclined, I wouldn't suggest doing that sort of thing yourself. I've done quite a few, however, I'm paid to do it. I'ts not that complicated a procedure, but if its improperly done, it can cause more harm than good. That,and you need compressed air to blow out the metal shavings from tapping the cylinder head once you are done. Most people don't have compressors at home.
Posts: 7,329 |
Jeff have you seen the plug holes on the V6...
Good luck getting a tap or heli-coil in there without the proper tools...
Take it to a shop. That way if the screw up and have to pull the head it's not on your dollar...
I've done the old style plug holes (steel & aluminum) on the motor, but would not want to try recessed holes in an aluminum head.
Posts: 47 |
Good advise! I have a compressor, tools and quite a bit of mechanical knowledge, however, I did not want to tackle this particular project. As a side note, driving home from the repair shop after the repair, the motor rattled and died  so i think a major cash outlay is close at hand  On the bright side I just bought a 2001 Corvette Z06 so at least I have an alternate ride
Posts: 1,421 |
the same thing happened 2 me blew the plug and spun a bearing made alotas noise after the heli-coil so it was new motor time 4 me
97 gsxr lotsa good stuff 4 sale 95 talon tsi awd turbo loaded sold 95 se 2.5 mtx loaded (fragile handle with care)2 motors 3 trannies custom y with hi flo cat,custom dynomax exhaust,upper cat mod superchip,udp,bat\kkm,proflow maf,ford 9mm wires,svt throttle body,svt intake manifold ,custom kevlar clutch,16 pd. flywheel,svt motor mounts ,svt gauges,eibachs\h&r,omp strut brace,dark chrome 16" rials with 225/50 dunlops,cwazy amounts of audio
Posts: 1,479 |
Spark plugs don't rip out all by themselves, some sub-sub-moron has to strip the threads in the head first!! So WHO last changed your plugs? or was it a FACTORY fault?
One beat'99 Tropic Green SVT
Posts: 1,421 |
it seems 2 happen on our motors and also the big ford diesel and the v 10's also
Posts: 5,805 |
Diesels dont have spark plugs!
Posts: 1,559 |
Nope they have glow rods...reminds me of those stupid glow worm dolls...
Posts: 5,805 |
Glow plugs on indirect injection diesels,none on direct injection diesels.
