#456509 10/10/02 09:50 PM
i have had problems with the second gear lately. under hard acceleration it wont go in right away from first to second. also it is very hard to downshift into second.
need help quick.
E0 T-Red SVT '98 S\/T K.I.A 6/14/02 AIM: p0lskipimp
#456510 10/10/02 10:32 PM
Drain Oil...
Install Cocktail...
Pete... 2004 Mercury Marauder 300A Black Clearcoat/Dark Charcoal LEATHER DOB 10/31/2003 DOP 1/2/2004 www.mercurymarauder.net
#456511 10/11/02 12:52 AM
TGO Offline
Make sure you use that dextron 3 stuff...using synthetic atf and the friction mod made my grind mre noticeable.
1999 Silver Frost SVT #609 of 2760 Quaife, lightened SVT Flywheel, SPEC stage II clutch, removed resonator, k&n drop in - various other goodies too.
#456512 10/11/02 12:55 AM
and what would the cocktail be?
#456513 10/11/02 12:59 AM
The cocktail would be Dextron III ATF mixed with 1/2 bottle of Ford Friction Modifier to help the synchros grab. I believe this is in the FAQ of this site. Ford Friction Modifier is readily available at most Ford dealerships. If you have synchros going out it is best not to use synthetic ATF. Start saving money for that tranny rebuild!
'98 SVT Contour, in at least 639 pieces 4 Speed MTX...synchro and shift fork replacement in progress
#456514 10/11/02 07:26 PM
how much $$$ am i lookin at here??
#456515 10/11/02 10:04 PM
how much of the Dextron III do i put in there along with the Friction Modifier?
#456516 10/12/02 06:47 AM
It should take a little less than three quarts of ATF and a half bottle of friction modifier. It's not that expensive so don't worry. Make sure to mix the friction modifier with the first bottle of fluid you put in so it all gets in there. It's actually easier than changing oil!
