Posts: 99 |
Hey Everyone, I have a musty smell coming out of my vents whenever I turn on the blower. Anyone else have this problem? It seems especially bad when I have it on the defroster setting. Any help would be appreciated as I am taking it to the dealer (my waranty runs out in two weeks)Thanks, Andreas
Posts: 1,367 |
try changing your cabin air filter. theres a howto in the faq section. here
Posts: 1,070 |
its mold. the air conditioning causes moisture so it turnes into mold.
you should run your heater after you use your ac to dry it out.
ford will have a temporary fix for it. you should also spray a disinfectant in there.
Proud former owner of..... '99 svt - silver/blue - #2555 of 2760
Proud new owner of... '02 BMW 330i
Posts: 283 |
Probably 99% of people experience the same thing. When you shut off the car after running the A/C or defroster, water continues to condense on the evaporator coil. This water makes mold happy (yes, a spore or two gets past the cabin air filter).
What the dealer will likely do is spray a chemical disinfectant into the cabin air intake. This won't be a permanent fix, though. As long as you're not allergic to whatever is causing the musty smell, you may just have to live with it.
One thing to try is to turn off the A/C compressor a couple of minutes before you shut off the car. That is, turn the selector to VENT and maybe even turn the thermostat toward hot. This will help the evaporator coil warm up to ambient temperature before you shut off, and should get rid of some of the excess water (which will then be in the air of the cabin, but oh well).
//> //> //> //> //> Garrick Silver E0, #3895 of 6535, built 10/2/97 She's stock. Why mess with a good thing?
Posts: 2 |
yes I have it too, no solution though Originally posted by SVTunit: Hey Everyone, I have a musty smell coming out of my vents whenever I turn on the blower. Anyone else have this problem? It seems especially bad when I have it on the defroster setting. Any help would be appreciated as I am taking it to the dealer (my waranty runs out in two weeks)Thanks, Andreas
Posts: 1,861 |
There is a TSB on this subject that provides part numbers to add an "after blow" kit. I just tried looking up the TSB, but the site is down. The dealer should be able to find in on OASIS with an air conditioning problem code.
The "after blow" is a control module that runs the A/C blower about 1/2 hour after shutting off the engine to dry out the plenum. I don't know of anyone that has tried it on our cars, but it works very well on other makes, such as some GM products and Volvos. For some Volvos this was the absolute answer. This system is a little pricy if you needed to pay for it yourself if the car is out of warranty.
If you don't add this kit, it does help to change the cabin filter. It also helps to deoderize the system at the same time. If you are doing it yourself, it is hard to find the best deordizer for home use, but Lysol works reasonably well. With the cabin filter removed, turn the A/C fan on at a low speed, continuesly spray Lysol into the hole where the cabin filter belongs for about a minute, then shut the fan off and allow the Lysol to soak in for at least 30 minutes (overnight is not too long) while you install the new cabin filter. You want the Lysol to soak into the walls of the case as well as the A/C evaporator core.
Best of luck with this.
Jim Johnson 98 SVT
Posts: 7,329 |
Yep.
Change the Cabin Air filter.
Also let turn the a/c off for a minute or two before you shut the car off. Less condensation.
Posts: 3,567 |
Originally posted by Big Jim: Lysol works reasonably well. With the cabin filter removed, turn the A/C fan on at a low speed, continuesly spray Lysol into the hole where the cabin filter belongs for about a minute, then shut the fan off and allow the Lysol to soak in for at least 30 minutes (overnight is not too long) while you install the new cabin filter. You want the Lysol to soak into the walls of the case as well as the A/C evaporator core.
Best of luck with this. I was goin got say the same thing
"careful man, there's a beverage here." e-mail: boseraq@hotmail.com aol IM: madhat1412
Posts: 99 |
Hey Everyone, Thanks for all your help! I still have about two weeks of warranty left so hopefully I can get the afterblow kit installed. I will try and look up the TSB for the kit. Andreas
Posts: 1,861 |
I found the recall. It is 99-19-5
Printable View (14 KB) Article No. 99-19-5 AIR CONDITIONING - MUSTY AND MILDEW TYPE ODORS - SERVICE PROCEDURE Publication Date: SEPTEMBER 13, 1999
FORD: 1994-98 MUSTANG 1995-98 CONTOUR, CROWN VICTORIA, ESCORT 1996-98 TAURUS 1995-98 WINDSTAR 1997-98 EXPEDITION LINCOLN: 1995-98 CONTINENTAL, MARK VIII, TOWN CAR 1998 NAVIGATOR MERCURY: 1995-98 GRAND MARQUIS, MYSTIQUE, TRACER 1996-98 SABLE 1995-98 VILLAGER
This TSB article is being republished in its entirety to add models.
ISSUE: Musty and mildew type odors may come from the air conditioning/heating system. These odors may be caused by mildew-type fungi growth in the A/C evaporator. It is most noticeable when the A/C is first turned on.
ACTION: A new Disodorizer® which encapsulates the mildew is now available to help reduce these odors. A new Moisture Purge Module (MPM) which operates the blower motor when the vehicle is parked to dry out the evaporator core is now available for these vehicles. Apply the Air Conditioning System Disodorizer® (F6AZ-19G210-AA or YN-18, or equivalent meeting Ford specification WSS-M99B187-A) product to the A/C system, install the MPM as directed in the following Service Procedure, and review the Odor Service Tips.
WARNING: AVOID CONTACT WITH EYES AND SKIN. CONTACT WITH EYES AND SKIN WILL CAUSE IRRITATION. WEAR SAFETY GLASSES WHEN USING THE DISODORIZER®.
WARNING: THIS PROCEDURE SHOULD ONLY BE PERFORMED IN WELL VENTILATED AREAS. OPEN ALL WINDOWS AND DOORS OF THE VEHICLE. LEAVE DOORS AND WINDOWS OPEN DURING THE ENTIRE PROCEDURE. AVOID BREATHING VAPORS.
WARNING: AVOID FLAMES, SPARKS OR LIT TOBACCO PRODUCTS. THIS PRODUCT IS COMBUSTIBLE.
WARNING: READ ALL INSTRUCTIONS AND WARNINGS PACKAGED WITH THE DISODORIZER®.
SERVICE PROCEDURE
A/C ODOR TREATMENT PROCEDURE
NOTE: THIS PROCEDURE WILL NOT BE EFFECTIVE ON ODORS EMITTED FROM AREAS OTHER THAN THE EVAPORATOR CORE. FOR EXAMPLE: MILDEW ODORS DUE TO WET CARPET WHICH ARE CIRCULATED BY THE A/C SYSTEM. BE SURE YOU HAVE IDENTIFIED THE TYPE AND SOURCE OF ODOR BEFORE PERFORMING THIS REPAIR.
The A/C System Disodorizer® (F6AZ-19G210-AA or YN-18) is a full strength disodorizer which requires no dilution or mixing. Each vehicle treated will require 240 mL (8 fluid ounces) to complete the procedure.
NOTE: THE ROTUNDA A/C DISODORIZER SPRAYER 164-R4700 IS ONLY TO BE USED WITH THE YN-18 A/C SYSTEM DISODORIZER AND SHOULD NOT BE USED FOR ANY OTHER PURPOSE.
The A/C System Disodorizer® can be applied using the Rotunda A/C Disodorizer® Sprayer 164-R4700. The disodorizer must be applied through the blower motor or the blower motor resistor/controller opening for proper coverage. Refer to the following Disodorizer® Application Location Chart to determine which component to remove.
DISODORIZER® APPLICATION LOCATION Model Year Vehicle Blower Motor Blower Motor Resistor/Controller 1995-98 Escort/Tracer X 1996-98 Taurus/Sable X 1995-98 Windstar X 1995-98 Town Car X 1994-98 Mustang X 1995-98 Contour/Mystique X 1997-98 Expedition X 1998 Navigator X 1995-98 Villager X 1995-98 Crown Victoria/Grand Marquis X 1995-98 Continental X 1995-98 Mark VIII X
NOTE: SPRAYER MUST BE CHARGED COMPLETELY FOR PROPER ATOMIZATION OF THE DISODORIZER®. FAILURE TO PROPERLY APPLY THE DISODORIZER® AS OUTLINED IN THIS TSB ARTICLE WILL NOT ALLOW ALL OF THE MICROBIAL GROWTH TO BE CONTAINED AND WILL RESULT IN AN INCOMPLETE REPAIR.
Open vehicle windows. Disconnect A/C cycling switch electrical connector. Set the following: A/C in vent or panel mode Temperature at full heat Blower at high speed Engine running at normal operating temperature Vehicles equipped with a manually operated fresh air/recirculate air door, set the door to fresh air position Run vehicle (Steps 1-3 conditions) for 15 minutes. This will dry out the system. Turn ignition off. CAUTION: BLOWER MOTOR RESISTOR MAY BE VERY HOT.
Remove and disconnect blower motor or resistor/controller (refer to Disodorizer® Application Location Chart) by referring to the appropriate Service Manual, Section 12 or Workshop Manual, Section 412-02. Insert the A/C Disodorizer® Sprayer (Rotunda 164-R4700) nozzle into the blower motor resistor/controller opening in the evaporator case and direct toward the face of the evaporator core. Spray the Disodorizer® until empty. Wait 10 minutes before proceeding. Reinstall and reconnect blower motor or resistor/controller. Repeat Steps 1-5. Reconnect A/C cycling switch. Allow vehicle to sit for 30 minutes before returning to customer. NOTE: REFER TO APPROPRIATE SERVICE LABOR TIME STANDARDS MANUAL FOR BLOWER MOTOR REMOVAL AND INSTALLATION OR RESISTOR REMOVAL AND INSTALLATION.
MOISTURE PURGE MODULE (MPM) INSTALLATION Install the applicable MPM and wiring harness. Follow the procedure in the Instruction Sheet provided with the wiring harness. Verify MPM operation.
ODOR SERVICE TIPS Types Of Odors, Their Sources And Treatments
There are typically four (4) types of objectionable odors found in a vehicle, they are:
Chemical odors Environmental odors Microbiological odors Human and other interior-generated odors Odors can be described in a number of ways:
Musty Mildew Fishy Sweet Burning Chemical Fuel Oil Exhaust Wet cement Urine Tar Fragrance Body odor Chemical odors:
Coolant: sweet smell Fuel: gasoline or diesel fuel smell Oil: oil type or burning smell Power Steering Fluid: oil type or burning smell Transmission Fluid: oil type or burning smell Washer Fluid: alcohol type smell Gear Lube: garlic/sulfur smell Refrigerant/Oil: ether type smell Carpet/Trim Adhesives: fishy, urine, or sweet smell Evaporator Core Coating: wet cement type smell Environmental odors:
Exhaust: exhaust, fuel, burning type smell Industrial Pollutants: all types of smells Dust: musty, mildew, wet cement type smell Pollen: sweet smell Tobacco: burning, tar smell Microbiological odors:
Microbial growth supported by warm temperatures and moisture may occur on:
Foam Seals: musty, mildew smell Rubber Seals: musty, mildew smell Adhesives: musty, mildew smell Standing Water: musty, mildew smell Water Soaked Carpet/Trim: musty, mildew smell Human and other interior-generated odors:
Secretion From The Human Body: body odors Perfuming Agents: sweet or fragrance smell Dirty Clothes, Shoes, Socks: musty, mildew, body odors Food/Beverage: sweet, musty, mildew, fishy smell The first step in diagnosing an odor concern is to verify the concern. To verify an odor you must determine when and under what circumstances the odor occurs and what type of odor it is.
Chemical odors are usually constant regardless of A/C setting and can be enhanced by A/C system operation. Most chemical odors are caused by fluid leaks and some are caused by improperly cured carpet and trim adhesives or evaporator core coatings.
Environmental odors usually occur for a short time and go away after the vehicle has passed through the affected area. These odors are usually only detected when a window is open or the A/C system is operating in a function that allows outside air to enter the vehicle.
Microbiological odors, if in the A/C system, usually last for about 30 seconds when first turned on and will be detected in both Max and Normal A/C. Microbiological odors occurring elsewhere such as from standing water in doors or kick panels or wet carpeting may last indefinitely and will be more intense in Max A/C. Microbiological odors will not occur at temperatures below 10°C (50°F).
Human and other interior-generated odors occur while the source is present and may linger for a short time after removal. These odors can be more noticeable during operation of the A/C system. They can be detected in the outside air position and may be more noticeable in Recirc.
The first step in getting rid of odors is to find the source of the odor. Once the source is found, it must be removed and the affected area cleaned or treated .
Chemical odors can be removed by repairing or replacing the component that causes the odor and then cleaning any residue that may have accumulated from the component failure.
Environmental odors usually cannot be removed due to the fact that they occur from external sources and are an everyday occurrence. They can, however, be minimalized by switching to Max A/C or Recirc mode.
Microbiological odors can be eliminated by removing the source and then treating the affected area. Standing water must be allowed to drain and dry out. A/C systems may be disodorized by using Air Conditioning System Disodorizer® (F6AZ-19G210-AA or YN-18, or equivalent meeting Ford specification WSS-M99B187-A) as described in the Service Procedure in this article.
Human and other interior-generated odors can be eliminated by removing the source and cleaning the affected area.
PART NUMBER PART NAME F6AZ-19G210-AA Air Conditioning System Disodorizer® (YN-18) F78Z-14K095-BA Moisture Purge Module Wire Harness Kit (Mustang, Windstar, Expedition/Navigator, Contour/Mystique, Taurus/Sable, Escort/Tracer, Villager, Continental) F7VZ-14K095-BA Moisture Purge Module Wire Harness Kit (Town Car, Mark VIII, Crown Victoria/Grand Marquis) F8XZ-19980-AA Moisture Purge Module (MPM)
OTHER APPLICABLE ARTICLES: NONE
SUPERSEDES: 98-10-2
WARRANTY STATUS: Eligible Under The Provisions Of Bumper To Bumper Warranty Coverage
OPERATION DESCRIPTION TIME 991905A Disodorize And Install Moisture Purge Module (MPM) - Town Car 1.9 Hrs. 991905B Disodorize And Install Moisture Purge Module (MPM) - Mustang 2.3 Hrs. 991905C Disodorize And Install Moisture Purge Module (MPM) - Windstar 1.4 Hrs. 991905D Disodorize And Install Moisture Purge Module (MPM) - Contour/Mystique 1.5 Hrs. 991905E Disodorize And Install Moisture Purge Module (MPM) - Escort/Tracer 1.9 Hrs. 991905F Disodorize And Install Moisture Purge Module (MPM) - Expedition/Navigator 2.0 Hrs. 991905G Disodorize And Install Moisture Purge Module (MPM) - Taurus/Sable 1.6 Hrs. 991905H Disodorize And Install Moisture Purge Module (MPM) - Villager 1.9 Hrs. 991905I Disodorize And Install Moisture Purge Module (MPM) - Crown Victoria/Grand Marquis 1.9 Hrs. 991905J Disodorize And Install Moisture Purge Module (MPM) - Mark VIII 1.8 Hrs. 991905K Disodorize And Install Moisture Purge Module (MPM) - Continental 2.1 Hrs.
DEALER CODING BASIC PART NO. CONDITION CODE ODOR 49
OASIS CODES: 208000, 208300, 208999, 290000
Jim Johnson 98 SVT
