Page 4 of 4 1 2 3 4
#455536 11/06/02 08:08 AM
Aren't MAFs "tuned"? If you remove them from their housing doesn't it potentially screw them up?
If you remove the air cleaner housing (which includes the MAF), you can spray some cleaner in there without removing the element at all.
Or am I being overly paranoid?
- Randall
95 Contour LX V6 Pioneer P1R + MB Quart + lots of amps!
#455537 11/06/02 09:14 AM
They sensor element is inside the sampling tube and thus protected from direct frontal assault. It's best to pull it out, but it is delicate, so be easy on it.
#455538 11/09/02 07:29 PM
OK...my car is having the same problems most of you here have discussed. It is the 2.5 liter engine. At 100,000 miles I had Ford do a tune-up: they changed the spark plugs, fuel filter, air filter, changed coolant, replaced the water pump, serpentine belt, transmission fluid, O2 sensor, idle control valve, and also the MAF sensor (but NOT the plug wires for some reason). All of a sudden my car started the bucking/hesitation/stumbling. I went ahead and replaced the fuel and air filters to see if that helped...it did not. The car only has 130,000 miles on it now - the plugs and sensors should be fine...so, my question is could the PLUG WIRES be the problem? They are 7 years old and have 130,000 miles on them. I admit I know nothing about cars...and this is bugging the piss out of me. I am a senior in college (a.k.a poor) and I need this car to last another 6 months at least until I graduate! Any help would be GREATLY appreciated. BTW, the check engine light is NOT on to indicate any emissions/sensor troubles, and the injectors were cleaned during the tune-up also. Thanks!
1995 Contour SE 2.5L Duratec V6 No mods, 130,000 miles Known as the "C-ride" =)
#455539 11/10/02 01:15 AM
Replace them...and smile when you feel how smooth the engine runs. I believe most people are getting about half that many miles on a set of plug wires.
#455540 11/10/02 11:59 AM
Try copper plugs and see if it solves the problem ($5 from Champion). It did on mine. I truly believe that there is a bad batch of Autolite/Motorcraft plugs out there that is causing all these problems.
- Randall
#455541 11/11/02 04:22 PM
E
E
I cleaned the MAF (soaked the filaments in a cap full of Gumout carb cleaner), let them dry, reinstalled, reset the computer and went through the learning process posted by mcgainer. Seemed to be awesome--big improvement & more power all around...but then it went quickly back downhill and seems worse than before. Did I do something wrong?
Steve
Steve 98.5 SE V6, Blue, MTX, SVT Exhaust, Knauberized, E1 Wheels, KKM, Kenwood! SOLD!
#455542 11/11/02 04:44 PM
I pulled my plug wires and guess what? Found one frayed near the boot. Put the Ford 9mms on witht the NGKs...no stumble. For kicks...reinstalled MotorCraft AWSF-32pps...and...still no stumble. So I guess my problem was in pulling the wires off the plugs I exposed some wire and it was short firing into the cylider head.
#455543 11/11/02 08:09 PM
I was able to get a chance to look at the car this weekend and would like to report my findings. Took the MAF apart, by removing the two security star screws, and gave the elements a few shots of throttle body cleaner (Gumout). Make sure you let them dry and watch the O-Ring for proper placement. I had taken the intake hoses off to do this, but it is not neccessary at all. The main reason I took the hoses off was to get easier access to the throttle body.
The TB was very, very dirty being that it has never been cleaned before. Shame, Shame. I have 127,000 on the car now.(Yes I drive a lot) Cleaned the TB out really well using the same cleaner. although I wanted to, I didn't remove it, because the parts shop didn't have a replacement gasket. I was able to hold the butterfly valve open and soak it with the cleaner. Used my finger and a couple brushes to clean it all up. Would be much easier, better, and quicker, to remove it.
Anyway, doing this has semmed to have solved my problem of the stuttering and hesitating around 40-45 MPH under load.
Also bought a new set of Bosch Double Platnums, but I haven't installed them yet. Want to drive it around some more and see if the hesitation problem comes back.
Hope this helps everyone who has this problem.
PS: I replaced the wires about 25,000 miles ago.
99 SE V6 Silver Frost 201,592 Miles (Still Running Well)
Page 4 of 4 1 2 3 4
