Page 2 of 2 1 2
#45522 09/21/01 07:17 PM
Noticed you said new cabin filter. I also notice alot of fog of windshield any time it is or has rained. When I replaced the cabin filter I added to the soft chaulking around the underside of the large plastic cover which has to be removed to get to the filter. You should use a very soft chaulking which won't dry out and is NOT at all adhesive you may want to remove the cover again. Pay particular attention to the joint between the cover and the windshield. I used rubberized speaker chaulking from www.partsexpress.com. [*]null
#45523 09/21/01 07:18 PM
#45524 09/22/01 12:55 AM
You said you have no A/C, that's your problem. The A/C dries the air so it can evaporate the fog on the windshield. No A/C means you're just blowing humid air back at it.
'99 Contour SE Sport V6, 5spd, Dark Blue / Blue
#45525 09/22/01 02:26 AM
labelle Offline OP
thanks for help , still working on it
hopping to fix it befor winter noticed a heater recall too look into maby this could be it
96 2.0 mtx
kenwood deck & amp,mtx cr, boston acustics,12inch phonix gold
45sq feet vibration dampning/sound proofing
15%tint
98 rims ,fire gta's
factory tack install
k&n ,intake res removed
accle thunder , ngk
custom exsaust
redline/fm , waterwetter , sy oil& stp
svt mounts
jet chip
#45526 09/22/01 04:03 PM
Mine had that problem too. My dad's Grand Am did the same thing. I just put some Rain-X anti fog treatment on the windshield and it hasn't happened since.
Warning: Management is not responsible for lost or stolen virginity.
'98 Zetec MTX
17 x 7 Enkei RS5 w/ 215/45/ZR17 Goodyear Eagle GS-D Import tires
30%Front/25%Rear Tint
JVC KD-S570, Clarion APA1200, 2 Soundstream Reference 10"s
"Powered By Ford" seatbelt pads
Pre98 Sail Panels
Removed resonator
Magnaflow muffler
Page 2 of 2 1 2
