O
O
From what I've read these Duratec's are very oil sensative. Most all oil change places put up to 5 qts. oil at a change, these cars need more than that. Once I get my car back next week with my new engine am I going to have to tell the oil change place that the car needs an extra quart at a change? How much oil do you put in your Duratec? :rolleyes:
95 Mystique LS V6
ATX
"Your on a need to know basis and you don't need to know" THE ROCK
1
1
5.8 Q
oh sh!t i only use 4.and a half quarts is that bad???????? doesnt seem to be any sound difference and the dip stick read ok waht whould i do?????
99 T-RED SVT
50,555 Miles and counting as off 7/12/2002
born jan 99
UR underdrive pulley
A Pillar Guages w/ AIR/FUEL VOLTS OIL PRESSURE "how to" members.aol.com/samplewon/apillarguageinstall.jpg
B&M short throw shifter
Eibach Springs
BAT Sturts
White Faced HVAC
2 ALPINE TYPE R 12" and ALPINE 1507 V12 AMP
Cup Holder Upgrade
PIAA super white Lows
Whelen 90watt 6 bulb strobe kit
Front end motor mounts
Mods waiting for install
3L(job has alrady begun, 3L totaly stripped.)
Quaife LSD
Apexi s-afc
Mirko splitter
Bad! eek
I suggest you read the manual! :rolleyes:
I use & recommend 6qts for the SVT
Std is 5.5qts older duratec and 5.8qt newer (use the search to find the year split I don't remember off hand and this topic has been done to death)
2000 SVT #674 - Check it out!
Not that anyone should benchmark my engine (save for a few folks), but mine takes 5.5 qts to read full on the dipstick. The oil pan baffle probably robs some volume in the oil pan. Because we had to "customize" my pickup tube to get it to fit, I know it's pretty close to bottom so starvation would be pretty unlikely. I keep a very close eye on that nasty oil light.
svttour, your oil light ever go off when driving, especially when turing right? Really bad mojo that light is! 4.5 qts is WAY too low. Don't want you to end up like me with a shot motor, unless you have a few grnd laying around and want to drop it on a 3.0 cool
6 quarts is perfecto. a lil over the line, but good.
-Dan
1998.5 SVT "Black and Blue" #5292
See here for MOD list.
"Washing your car to make it rain does not work."
I use 6 qarts and it seems to be fine, a tad bit over the line, but nothing too major
Chow
1998 SVT #2263 of 6535
chowsvt@msn.com
ya ive always used six... even when id bring a box of mobil 1 to ford to do it becasuse my lack of time, the used all 6 qts too
99 svt contour
-its fast. period.
91 mustang gt
-its faster. period.
86 Buick Grand National
- its way faster, double period!
V
V
Full 6 here
APT Offline
Six full.
