Posts: 154 |
When I bought my 98.5 E1 this past June, I replaced the burned out passenger side fog light bulb. Now only 3 months later, it's out again! I checked, and the bulb really is burned out (i.e. not a faulty connection, etc.). The original driver's side bulb is still going strong (I replaced them both at the same time). Has anyone else had this problem? What is the life expectancy of a fog bulb? 3 months seems AWFULLY short!  TIA
-Chuck Dienzo "Taxation WITH representation isn't so hot either!" Black 98.5 SVT, lightly modded Born on 3/16/98
Posts: 674 |
are you being careful not to touch the glass on the bulb element?
the oil from your hands will cause premature burnout.
99 SVT Black/Tan #1311/2760 Born 3/2/99 17x7.5 Momo Racers yoko A520's, Loud Beats,KKM,Bullet Fuel door,Fog Fix & 885's,9005 Silverstars, RichBrook CF Knob.
Posts: 974 |
Water, Water, Water in glass housing! Mine leaked like crazy! Take a piece of paper towel and soak in the housing after bulb is out. If it is even damp, then water is most likely your problem.
2001 Cavalier 150-175 more kms per tank of same size Pioneer 12 CD Changer
SOLD Green 98 Mystique GS Sport Zetec ,ATX 885 Fogs mod. Hi beam mod. 205 15s
Posts: 88 |
Any loose or intermittent connection can cause an inductive "kick" in voltage. Any vibration can cause failure of a bulb at its most vunerable time, i.e. right after it's turned off and before it cools. Let us know if you find any of the stuff mentioned.
'98 SE V-6 5-spd ASB Silver stock 48K miles in May '02 Like it for Oregon coast canyons!
Posts: 308 |
I have the same problem, but only on the drivers side!! I don't know why, no water, short, and it's not loose. I have just gotten used to it, sorry?!?!?
Keith....
99 SVT Green/Tan #44 TH-Fix, Aussie Pipe, PRO-M, SHO-Shop Y, Borla, and other Misc. 93 Tracer LTS Eibach, K&N, Misc (now my winter beater) email me: keith@thinkingcapdesign.com My Car: http://www.thinkingcapdesign.com/KeithsSVT/
Posts: 36 |
Yup mine also, now iv'e replaced both.
00' Silver Frost SVT #1551 of 2150 born 1/13/00 Mobil 1 Sth. oil K&N drop-in 88' Dodge omni
Posts: 1,537 |
Try using WAGNER bulbs.
Pete...
Pete... 98.5 SE Sport Duratec ATX (P66L) Black Clearcoat on Greystone DOB 11/21/1997 DOP 12/25/1997 PIAA 510 Super White Driving Lights SVT CAT-BACK EXHAUST (No Resonator) DiabloSport Chip (LPQ4) - Engineered To Raise Hell Too many other mods to list... Sounds sweet, runs quick... Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
Posts: 960 |
Wagner is crap. I've had the same Sylvania 885 bulbs in for 18 months now. I use them all the time at night and as DRL's too. Beat that.
96LX/24V/ATX/Midnight Red/A4 repeaters/SVT exhaust/KKM/65mm throttlebody/SVTsprings and ST200 struts/SE rockers and BAT spoiler/BAT 19mm swaybar/urethane bushings/Kenwood 7 speaker syst./E1 SVT brakes w Powerslot rotors/9005 lowbeams/885 fogs/50% tint/Michelin XM+S 130's for winter/E1's with gForces for summer...and now "New Paint!!" 87 Renault GTA convertible/2.0l/mtx/Sony sound/otherwise stock http://members.shaw.ca/neilmc/
Posts: 4,899 |
Sylvania is the best. Trust me. Always had Sylvania, they've never burned out. As of a few months ago, I was still running on the same 893 that came with the car (switched to 885). Moisture might be the problem. Do you run your fogs for extended periods?
Posts: 154 |
Thanks for all the tips, guys. Unfortunately, none of your suggestions seem to be the problem.  1. I know for certain that I didn't touch the bulb. 2. There's no apparent moisture problem. 3. I pretty much only run them at night. 4. Still checking for loose & shakey connections, though. Well, I guess I'll just wait and see how long THIS one lasts... :rolleyes: Again, thank you.
