Posts: 383 |
When I turn on my A/C, it smells like cat urine for the first minute.
What up?
Posts: 4,476 |
need to change your filter - check the FAQs
Todd Christ SVT Contour Registry MODS: KKM Intake, SHO Shop Y-Pipe, Bullit Fuel Door, Edelbrock RPM Resonator '98 E0 SVT Contour #1037 of 6535
Posts: 200 |
Yeah, replacing the filter is easy - just make sure you note the orientation of the old one when you take it out. There's only one way to get the filter in, and it isn't fun if you do it wrong.
BTW, do you have a cat who might be responsible for the odor? :p
*** Sidewinder: 1999 SVT Thud: 1998 SE V-6 Edgecrusher: 1998 Mercury Mountaineer, 5.0L
Posts: 334 |
You can always spray in a fungus kill spray. It basically kills the fungus that grows sometimes in the vents from the ac..cost like $10, worth while to try that first. (AC SPRAY OR SOMETHING LIKE THAT) :p
98 Contour V6 MTX KKM/Niehoff Wires/Bosh+4/Mobil 1 Oil/Tranny/Pioneer CD/Speakers Predator Alarm...more 2 come!
"Dana, if by accident, I dropped an 7mm rachet inside your secondaries your engine would be ok? right?" "Trust me if I could go back and change, I would be stuck in the past" MartinS
Posts: 82 |
Do you smoke? Do you run the AC on MAX? You don't want that smokey air recirculating back through the coil. I learned that lesson real bad with my last car. That, or a cat p!ssed into your car.
'99 Contour SE Sport V6, 5spd, Dark Blue / Blue
Posts: 3,421 |
Hey swalve i see your from chicago. why dont you post in the Chicago section. and second i also had the smell. well i changed the filter and its still there. dont know why but its pissing me off.
Posts: 383 |
thanx for the responses. I don't smoke nor run max a/c. I'll replace the filter. thanx.
Posts: 3,598 |
Recap of the above. Change your cabin air filter, and (while AC is on MAX) spray some Lysol or similar anti-bacterial freshener into the return ducts to kill any mold that is in the ducts.
\'94 Cobra #4963/5009, black on black, not quite stock Formerly owned a black '00 SVT, #1972 Join the SVTOA! RIP - Ray "Old Fart Emeritus" McNairy
Posts: 2 |
so where are the return ducts?
Posts: 3,421 |
Cool thanks for the Info Steve
