Posts: 10,015 |
Spent another $215 at Summit yesterday and got these:  0-1600°F Full Sweep EGT Gauge  -30inHg/20psi Boost Gauge  And the 0-100psi Oil Pressure Gauge (the one on the right) I also ordered an A-Pillar Pod ($39.95) from SP Motorsports to mount them, and I went ahead and ordered SS brake lines too ($99.90), to help slow down the beast with all this new extra power!  Someone take my Credit Card from me quick! ha ha ha
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 1,786 |
Now all you need is a turbo tach!
-Auto Mak or-
-Experiment or
-Station Wagon or-
-Computeriz or-
I have a foot that is bigger than a foot.
SuperChipFOR SALE
Posts: 9,602 |
Originally posted by Chris Hightower: Now all you need is a turbo tach!
Don't forget the Turbo Timer. You want to give the hot high spoolin' turbo a chance to cool down.
Then again with the PATS system this may pose a bit of a problem!
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 646 |
Originally posted by Chris Hightower: Originally posted by PoopStainz: does teh turbo work on an ATX ?
It will soon enough. My Contour is ATX and it is getting the turbo.
-Chris
looks like someone is going to be the first guy with a level ten tranny. as the stock tranny cant take anything over 200 hp from what i heard. i mean read.
Experience is the worst teacher; it gives the test before presenting the lesson.
Why do you need the cats when u have dogs
04 WRX - TOTALED 3-5-05
Previoius Owned: 96 Contour LX with svt kit
Posts: 10,015 |
AUSSIE ENDLINKS $70
Posts: 5,810 |
I think that as long as you keep the switched ignition power on the the pcm, it will not activate the pats. It only does the pats test when the ignition is first turned on. A relay that keeps the power on should allow the car to stay running as needed.
warmonger
See My Mods
Posts: 10,015 |
If you're right and it only looks for the PATS at start-up then it should work easy, without even a relay - I hope.
AUSSIE ENDLINKS $70
Posts: 7,025 |
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 10,015 |
Passive Anti Theft System. That chip in the key that stops people from "hot-wiring" your Contour (not sure if pre-98's have it though). I ordered an A'PEXi Auto Timer - it's a turbo timer, A/F ratio gauge (actual ratio!) and it also measures battery voltage, etc for the 'Tour, so I'll see if I can get it to work. http://www.apexi-usa.com/electronics_timer.aspI got the S-AFC to work for us, so this shouldn't be an issue.
AUSSIE ENDLINKS $70
Posts: 7,025 |
do u suggest using the apexi safc or the greddy emanage?
and how much was the apexi auto timer? btw, i just read about it on apexi's site and thought this was really cool, "To prevent potential theft while running, the handbrake safety feature shuts off the vehicle when the handbrake is released without the ignition key."
Jim Hahn
