#45364 09/09/01 02:58 AM
1
1funsvt Offline OP
1
When I turn on my A/C, it smells like cat urine for the first minute.
What up?
#45365 09/09/01 04:30 AM
need to change your filter - check the FAQs wink
Todd Christ SVT Contour Registry
MODS: KKM Intake, SHO Shop Y-Pipe, Bullit Fuel Door, Edelbrock RPM Resonator
'98 E0 SVT Contour #1037 of 6535
#45366 09/09/01 04:33 AM
Yeah, replacing the filter is easy - just make sure you note the orientation of the old one when you take it out. There's only one way to get the filter in, and it isn't fun if you do it wrong.
BTW, do you have a cat who might be responsible for the odor? :p
Sidewinder: 1999 SVT
Thud: 1998 SE V-6
Edgecrusher: 1998 Mercury Mountaineer, 5.0L
#45367 09/09/01 04:43 AM
You can always spray in a fungus kill spray.
It basically kills the fungus that grows sometimes in the vents from the ac..cost like $10, worth while to try that first.
(AC SPRAY OR SOMETHING LIKE THAT) :p
98 Contour V6 MTX
KKM/Niehoff Wires/Bosh+4/Mobil 1 Oil/Tranny/Pioneer CD/Speakers
Predator Alarm...more 2 come!
"Dana, if by accident, I dropped an 7mm rachet inside your secondaries your engine would be ok? right?"
"Trust me if I could go back and change, I would be stuck in the past" MartinS
#45368 09/09/01 06:30 PM
Do you smoke? Do you run the AC on MAX? You don't want that smokey air recirculating back through the coil. I learned that lesson real bad with my last car. That, or a cat p!ssed into your car.
'99 Contour SE Sport V6, 5spd, Dark Blue / Blue
#45369 09/09/01 06:39 PM
I
I
Hey swalve i see your from chicago. why dont you post in the Chicago section. and second i also had the smell. well i changed the filter and its still there. dont know why but its pissing me off.
#45370 09/09/01 06:48 PM
1
1funsvt Offline OP
1
thanx for the responses.
I don't smoke nor run max a/c.
I'll replace the filter.
thanx.
#45371 09/09/01 08:42 PM
Recap of the above. Change your cabin air filter, and (while AC is on MAX) spray some Lysol or similar anti-bacterial freshener into the return ducts to kill any mold that is in the ducts.
\'94 Cobra #4963/5009, black on black, not quite stock
Formerly owned a black '00 SVT, #1972
Join the SVTOA!
RIP - Ray "Old Fart Emeritus" McNairy
#45372 09/10/01 12:59 AM
so where are the return ducts?
#45373 09/10/01 02:25 PM
I
I
Cool thanks for the Info Steve
