#451855 10/04/02 09:09 PM
ok it's been some time since i wrote on this page. i'm liking the new faces so recently the hood on my 91 corsica flew up on me on the freeway......so i decided to fix the contour. What was wrong with the tour? you might wonder.... well $720 for a new power stering pump, pulley, tensioner, and a serpentien(i know i didn't spell that right)belt, which was replaced about four months ago. Nothing but problems with the tour. 95se w/83k RIGHT NOW THE AIR BAG LIGHT WILL NOT STOP WITH THE 4:5 RATIO Can someone help me out a little??
