Again Fellow memebers, we are looking for only
5 dedicate people at the onset, [u]NOT THE MASSES[/u]!!! I'm sure out of the 1,000's here at CEG and NECO, there must be at least 5 that can afford to put there car on stilts for a short while.
As far as the cost of this program, plz refer to the Group Buy Section as most of you know, no Prices can be revealed in this Section. I'd like to say that this is by far the cheapest CNC process you will come across on a pair of heads. The reason for the low initial cost, is I really want to get this started so we have a new modification to be had for this seeking more power. If both Terry & I get together on this, which I have discussed with him already, we will probably work on a complet package, 2.5 & 3.0 of some sort. I honestly hope that with the Haines and PXRacing connection we can develop a full motor program, with honest to good hp numbers easily exceeding the 300hp range Naturally Aspirated.
Hows that sound for STARTERS!!!
