#45053 08/15/01 01:17 PM
I'm gonna clean the MAF sensor long with the throttle body, replace the spark plugs and other misc. tune up items. What do you recommended to clean the MAF sensor?
99' Sport 2.5L
#45054 08/15/01 02:21 PM
N
N
You might do a search on "MAF Sensor". I seem to recall someone was using carb cleaner, although I want to do the same thing and would probably use throttle body cleaner. Use it sparingly from what I heard so as not to damage the two thin wires which take air readings.
Also around the throttle body make sure to unclog the "holes" in it, again from what i remember that's a common gripe. They get clogged up with greasy soot.
Good luck!!!
#45055 08/15/01 02:22 PM
N
N
a search on Contour.org that is. up and to the right a little
#45056 08/15/01 03:23 PM
E
E
Having had the Mass air (I mean the sensor OUT of the unit) apart a zillion times (smoothing out and enlarging the bore on a spare one)I can say TB cleaner or brake cleaner (non clorinated) will clean the Mass air. Be careful spraying it straight into the small opening for the sensor. The sensor is suspended on two tnin but strong wires and is a coated wire. It can take a bit of pressure and not collapse, but be careful.
One beat'99 Tropic Green SVT
#45057 08/15/01 07:38 PM
thank you all for your help, i'm contemplating what else i can do to tune it up. I haven't looked personally, but off hand, does anyone know where the fuel filter is located and how easily it is to change on the contour?
99' Sport 2.5L
#45058 08/16/01 12:32 AM
Cleaning the MAF is highly NOT recommended. Don't do it unless there is a problem and you may need to replace it anyway. I have seen them damaged from attempts to clean them when there was nothing wrong. Don't do it as a maintenance proceedure.
Jim Johnson
98 SVT
#45059 08/16/01 12:46 AM
I would also suggest finding out WHY it got dirty!.Bad PCV system can cause excessive 'oil mist' blowing back in the accordian tube or aftermarket tube,fix the 'root cause' aswell as 'bandaiding' the MAF !
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
#45060 08/16/01 02:02 PM
Fuel filter located under car near back rear tire (passenger side!)
2001 Cavalier
150-175 more kms
per tank of same size
Pioneer 12 CD Changer
SOLD Green 98 Mystique
GS Sport
Zetec ,ATX
885 Fogs mod.
Hi beam mod.
205 15s
#45061 08/16/01 03:55 PM
You really don't need to clean the sensor. There shouldn't be any contaminants touching it. Don't screw up -- they are expensive to replace!
Dan Parmelee
1999 Acura Integra SiR-G coupe
"I heard Affleck was the bomb in Phantoms"
"Word, bitch! Phantoms like a muhfuka"
#45062 08/16/01 08:07 PM
Well, i'm not really cleaning the MAF just as maintenance, i posted another topic about a 99SE making diesel truck (not very loud, but noticable) so i'm trying to troubleshoot that issue. if cleaning the MAF doesn't help, i'll move on.
99' Sport 2.5L
