Posts: 1,165 |
I'd hate to ask a stupid or otherwise obvious question, but why are you relocatting your battery anyways ? Are you prep'ing up for a turbo or supercharger kit ? Tim
'01 GTP: 3.3" pulley, Headers, 3" Exhaust, Straight Pipe, Intense Air to Water Intercooler. Pictures
Old Ride: 95 Mystique LS V6 ATX: Pictures
Posts: 3,867 |
Either making room for forced induction, or just for better weight distribution. Our cars are nose heavy, and left-biased. Note that in the right-hand drive version, the engine bay looks the same, but in our cars the driver and 60 lb battery sit on the same side of the car. You can feel a difference on the autocross course between hard left turns and hard right turns.
A bit like flying a Sopwith Camel.
Function before fashion.
'96 Contour SE
Posts: 25 |
i was relocating the battery to free up some space under the hood. I was getting to much heat soak, so I removed the battery and the battery bracket(which was a pain in the ass), now the filter breathes a how lot better. i also ripped out the old tubing that was in the fender from the airbox. Then i cut a hole in the upper front of the wheel well (its not noticable unless you look up in the well) This allows air from the engine bay to get suck out through that hole in the inner fender from the old airbox and out through the wheel well where i cut the hole, it getts sucked by outside air passing the wheel well creating suction. maybe it is just me but i noticed a diffrence. A lot less hot air is being sucked in through the filter.
95 contour
2.5
intake,exhaust,removed resmagnecore wires
--Superchip Blue module PEW4--
Battery Relocated
Posts: 175 |
Originally posted by RogerB: A bit like flying a Sopwith Camel.
Wasn't the Sopwith Snipe a little worse?
Posts: 3,867 |
Well, you've stumped me there.  But nice to know someone else gets what I'm talking about. Of the Camel, it was said In reply to:
"A great number of trainee pilots had been killed learning to fly this machine, as its tricks took some learning, although they were really simple to overcome. Its main trouble was that owing to its very small wingspan, and its purposely unstable characteristics, coupled with the gyroscopic effect of a rotating engine and propeller, it flipped into a spin very easily at low speeds. Consequently, in landing and taking off, a tremendous number of fatal accidents occurred, and a general felling of dislike for the machine was prevalent. It really had people frightened." Arthur Cobby
Of the Snipe, however, In reply to:
A descendant of the Sopwith Camel, the Sopwith Snipe was equipped with a more powerful engine and provided better visibility from the cockpit. Though not much faster than the Camel, the Snipe had a better rate of climb and pilots found it much easier to fly.
Source: The Aerodrome
'96 Contour SE
