Posts: 2,387 |
I was just on ebay and saw this, it comes with k&n, has the attachment plate, and comes with the pipe which erradicates the accordian tube for the price of the kkm. Even the filter doesent seem to be inverted, so that too can help with hp. What do you think Intake
98 3.0 svt: Sold
Posts: 1,084 |
Fifteen men on a dead man's chest...
Maverick Machineworks is open for business!! Tell me what you need and I can make it!
Posts: 974 |
If you did a search you would have noticed I posted stuff about this intake as well earlier this month. Several people on here own this intake. If you keep watching he putts several up for buy it now 88.99 about once a week or so. I am thinking of either getting this intake or the SHo SHop...the only thing with this is that you need to either build or buy a heatshield.
Posts: 974 |
Someone said that if you have a non SVT then you have to do some little things to this to get it to work...just FYI. Also the estimates he makes on gains of both hp and torque seem high...maybe that is to the crank though.
Posts: 857 |
The KKM, Mirko, etc MAF adapters are all CNC-machined billet aluminum. IIRC the MAF adapters on ebay are basically a section of metal aluminum pipe welded onto an aluminum plate with a hole cut in it. Notice how they carefully avoid head-on pictures. Be careful, see if he has more pictures.
Posts: 2,857 |
that one seems ok...alot of the stuff on ebay is junk though...i'd also like to see his maf adapter plate...and that filter looks pretty small...don't expect the #'s he's claiming either...
new,new ride!
'99 svt
black/mnb
'95 mustang gt sold!
'98 svt #800 sold!
Posts: 35 |
Originally posted by louisw: The KKM, Mirko, etc MAF adapters are all CNC-machined billet aluminum. IIRC the MAF adapters on ebay are basically a section of metal aluminum pipe welded onto an aluminum plate with a hole cut in it. Notice how they carefully avoid head-on pictures. Be careful, see if he has more pictures.
I ordered one of these kits late on 9-27-02 and I got it today 10-02-02. The MAF adapter is machined billet aluminum and it came with the same KN filter as pictured on Ebay there is a couple small burrs in the Aluminum Piping part this is an easy fix with a small file or a Dremel. I will post pictures if I can get my buddy's digital camera. For the 88.00 plus 9.99 s/h I would get this setup, it is for the 65mm TB would be easy to use on the 60mm TB just get a smaller reducer locally.
97_contour _sport
Added T-red wing
Cougar big brakes
DMD pulley
SS brake lines
Ford 9mm wires
21mm BAT bar
SVT motor mount
ES bushings
Metal water pump
ST200 badges & mats
ST200 UIM/LIM
Cold air intake
BAT Y-pipe
Posts: 541 |
i bought one too for my SVT and should be getting today or tommorow, will post pics and comments after install, but all i've heard is good things about this intake, so we will see!
2000 CSVT (SOLD)
#531/2150
now
2003 WRX
!FINALLY SPONSORED!
"Big Pimpin, Never Slippin"
Posts: 974 |
I want to get one for my mystique....now isnt there 1 extra hole in the intake pipe? What modifications if any am I going to need to make in order for this to fit?
Posts: 541 |
none from wat they say. here is a pic!
2000 CSVT (SOLD)
#531/2150
now
2003 WRX
!FINALLY SPONSORED!
