Page 1 of 3 1 2 3
#44885 08/03/01 02:38 PM
I realize other aftermarket rear sway bars have clunked, but it seems like they clunked during lateral motion (corners). I have a clumking noise from vertical movement, (dips and bumps) particularly at lower speeds.
I have the BAT/SP Motorsports 22mm bar, which I haven't heard any other clunking issues for.
Are there other things I should look for to see if they're the problem? How can I check or tighten the rear sway bar?
Thanks in advance,
James.
You can pillage an enemy once, but a customer is an endless resource.
James Oerichbauer - PFPC Global Fund Services
Ross: 1998 E0 SVT Contour, Toreador Red, Konis, Superchip, KKM w/heat shield, SHO-shop y-pipe and rear strut brace, no res, ScotchCal, Moda Sport 16x7.5 wheels with 205/55ZR16 Dayton Dayton tires... more
#44886 08/03/01 02:44 PM
V
V
I am having the same problem on my '96 Mystique. I have a funny feeling it's the sway bar links at then, that connect to the control arm, be sure to checke the bushing in the arm also. Also pay close attention to the sway bar stops that are on each side of the bar, nect to the sway bar bushing.
There was a time when we were replacing sway bars all the time.
Bill Jenkins
Signature L/M as of 06-01-02
parts@signaturelm.com
http://www.signaturelm.com
#44887 08/03/01 02:44 PM
pssst..pssstt...your U brackets are bent. Take them off and bend them back. But don't tell anyone I told you. smile
#44888 08/03/01 04:46 PM
Where are these V brackets??? Or are you talking about the bracket that holds the sway bar on rod bushing in place? Tell! Tell!!! frown
Or are these the brackets that hold brake cable up! Come on!!
2001 Cavalier
150-175 more kms
per tank of same size
Pioneer 12 CD Changer
SOLD Green 98 Mystique
GS Sport
Zetec ,ATX
885 Fogs mod.
Hi beam mod.
205 15s
#44889 08/03/01 05:07 PM
Yes, thanks for the info, but I wouldn't know what these parts are if they bit me.
Can anyone translate the mechanical terms into English or make it so that when I'm at the car I can tell by sight what I'm looking for?
Sorry, but I'm a mechanical idiot!
#44890 08/03/01 06:29 PM
I have the same problem, Please post...
or email Amata@ortc.com
Silver 98 SVT Contour E0
#4124 (Currently on Life Support)
Built 11/97 Bought 1/98
Eibach Pro Kit \ Koni \ Niche Pultec 17"x7.5 \ Yokohama Parada 215/17/40 \ Shaved Wheel wells / Brembo-KVR Cross Drilled Rotors / KVR Carbon Fibre Brake Pads / Aeroquip SS Brake Lines \ 21mm Rear Progress Tech. (Powder Coated Black) \ Superchips Auto Meter Pro Shift Light \ Extrude Honed \ Stripped Resonater Street Scene Free Flow Exhaust \ Injen Technology Prototype CAI \ Weapon R filter \ Hose Techniques Red Kit \ Folia Tec Red Caliper Paint \ MOMO (shift knob, pedals, seat belt pads) \ Clarion, Sounstream, Kicker \ Optima Red Top Battery \ SVT Emblem Mods
Jet Hot Coatings (25-30% Cooler) on Upper Intake Manifold, Sho Shop Y-Pipe, Cat, and CAI
"Come Out...Come Out Where Ever You Are"
http://www.geocities.com/speeddemons19
#44891 08/04/01 04:31 PM
me too, same problem
#44892 08/06/01 09:08 PM
call sca they have a fix.....sorta....
if you have one of the odd sized gas tanks, like me, you wont be able to put the brackets on the driver side.
call them and put pressure on them.....ask them questions.
ford can temporarily fix this problem also.
Proud former owner of.....
'99 svt - silver/blue - #2555 of 2760
Proud new owner of...
'02 BMW 330i
#44893 08/06/01 09:09 PM
where are the "U" brackets?
anthony, your having trouble with the bar????
'02 BMW 330i
#44894 08/07/01 11:28 AM
I
I
The U-Brackets are being held in place with one bolt - bolted to the frame.
What I did to eliminate the problem was weld both brackets to the frame to eliminate the clunk and brackets moving out of place when cornering hard.
But, I have also replaced my endlink rubber bushings with polyurethane, so the stiffness contributed to some of the problems.
If you dont have welding tanks, you can go to a Muffler Man or Midas and tell them to specifically weld the brackets to the frame.
I hope this helps.
99 Range Rover 4.6 HSE
Mystery Car??????
Page 1 of 3 1 2 3
