I have a 1995 Mystique 2.5L. Based on the fact my WP was replaced about 40K miles ago, like may others in the CEG, I decided to replace this pump with an all-metal one. I followed Don Craigâ??s instructions, but it still was a pain to replace. The first problem I had was trying to remove the old gasket from the housing surface. It was extremely difficult to reach certain areas. So, I decided to remove the housing. This helped a great deal. I was able to work with it on my bench. As the instructions stated, I removed the cable that is attached to the ATX. While replacing the front half of the WP I hit the plastic cover that is attached to the ATX module and broke off the plastic flange that is used to lock the connector into place. What a pain in the butt. For now I used a tie wrap to hold it into place. Will the tie hold up with the heat of the engine compartment? Is there a better way of holding the plug in place?
