Posts: 1,616 |
Cheap mods (under $100)
***Flaming Disclaimer!! All prices are either guestimates are what I've paid. You can find better deals if you search or have patience.
AFE Drop in Filter - $50 Drilling holes in Filter cone - priceless! New spark plugs - $40 (Either motorcraft or NGK) Mobil-1 - $30 (for 5.5 quarts...and I know I felt a difference!) New plug wires - $50 (see post in GB section) Synthetic Tranny fluid - (Mobil-1) Replace Brake fluid - (Big bottle Syntec from AZ) Brake pads - (A matching set all around...nice and even performance/wear. Stazi's were $87 for F/R to my door. Perform a little better than stock, and hardly any dust!) 1 bottle electronic parts cleaner - $5 (pull your MAF and gently spray/clean it) Replace stock resonator - $80 ($40-50 for a Mag or Edelbrock, and $30 for install. Not sure about HP...maybe 1-2, but love the sound!) 4 wheel alignment - $60 (can you say no more dog-tracking?) Remove the ding guards - Also priceless Bnoon TB Optimization - $60 ($169 total, but he refunds $100 when he recieves your TB...3 HP) Poly sway bar bushings - $20 (for F/R...I'll do your fronts...HAHAHAHAHHAHAHHA!) Braided Brake lines - $100 (F/R if you don't count shipping!)
I put this list together for New CSVT owners. Yes, you can optimize the stock Y-pipe, pull the UIM and LIM and clean them, do some gasket/port matching, get a used Pro-M, etc...but I felt the above list was something anyone could do in their driveway, with minimal skills, and feel solid results.
Please feel free to add to the list.
Posts: 3,732 |
Russell
Oval Port 3L Nearly Done
Posts: 107 |
HOW?!  ?! Every place I've went, least price of a 4 wheel alignment was like $90 all the way up to $145! I must be looking in the wrong places
Posts: 1,840 |
Originally posted by MIdnight95SE: HOW?! ?! Every place I've went, least price of a 4 wheel alignment was like $90 all the way up to $145! I must be looking in the wrong places
Mine was $64. I think $60ish is pretty much average around here...
Posts: 3,732 |
im good friends with the manager at the local tire shop
Russell
Posts: 6,198 |
Painting front oval body color.....priceless Painting rear chrome strip black.....priceless Painting sail panels black.....priceless Clearing corners in headlights....priceless Removing door ding guards....priceless Painting interior trim pieces....priceless Lowering through H&R springs....priceless Fog light fix....priceless
In actuality...., About $30 (becuase I had to buy paint, which I still have most of). $4 $4 (same $4 as above) $10 (for silicone and clear bulbs) $0 (used stuff I had around the house) About $25 (for paint and prep supplies) Enough...install is what killed me here $0
Posts: 3 |
by the way there are no alinment's on the contour. just toe adjustments. no caster or camber.
Posts: 2,580 |
"Painting front oval body color.....priceless" I think painting the Blue Oval a different color is :P.  Blue Ovals should stay BLUE!
2005 Nissan Sentra 1.8 SE, Code Red. '00 Tropic Green Ford Escort SE [Contour's little cousin]
Posts: 1,084 |
he means that chrome ring around the grill
Fifteen men on a dead man's chest...
Maverick Machineworks is open for business!! Tell me what you need and I can make it!
Posts: 3,867 |
Originally posted by Blue 'Tour: by the way there are no alinment's on the contour. just toe adjustments. no caster or camber.
Well, officially. A good alignment shop can give you a teency bit of negative camber, like around 1 degree.
Function before fashion.
'96 Contour SE
