#44700 07/11/01 04:55 PM
SVT Offline OP
I have a 98 SVT with 50,000mi. I am now getting a noticible pulse in brightness of dash lights and overhead interior lights. I the pulse quickens with a rise in rpms.
I have installed an OPTIMA battery last fall. Additionally I have a stereo amp that I fail to turn off every day (which could have been the demise of the original).
The car turns over rapidly and the pulse almost could be defined as a surge, as if the voltage regulator was shot. I have no problems starting but as of this morning the battery warning light has begun to flash in conjuction with the dsah lights.
Any Ideas?
Thanks
Ryan
Toreador Red
1998 SVT #2843
"Performance in the hands of few"
#44701 07/11/01 10:12 PM
Sounds like the diode pack is on its way out in the alternator,use a dightal v/meter,should get 13.5-15volts steady at around 1200rpm with all loads off.
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
#44702 11/02/01 12:47 AM
On my 96 Contour my lights started to dim as well as my transmission did not shift into overdrive and my car was idling high before this happen, my car was warm though. Do you think this might be my alternator and if it is tell me how much this is going to cost me??
#44703 11/02/01 02:55 AM
I posted about this before, but I noticed that if you have the high beams in the low position and hit your turn signal, the alternator overloads or something and that headlamp dims with each flash....
Dan Parmelee
1999 Acura Integra SiR-G coupe
"I heard Affleck was the bomb in Phantoms"
"Word, bitch! Phantoms like a muhfuka"
#44704 11/02/01 05:09 AM
My electrical system is all stock and I'm having the same problem????
jose 97
Jose 97
97 SE T-Red 24V MTX built 4/96 Mods LOTS!!!
#44705 11/21/01 08:24 AM
I'm having the same problem with my 99 contour...
http://www.contour.org/cgi-ubb/ultimatebb.cgi?ubb=get_topic&f=3&t=003052
this is another person w/ the same prob.
1999 SE Sport
ATX, Red, 2.5l v6
Eats ricers for breakfast smile
Currently No mods
#44706 11/21/01 10:35 AM
E
E
I priced a replacement once when I was still at Checker. For a Zetec it is very close to $200. eek
· Jon Miconi
· 96 Contour Zetec ATX
· 80 Ramcharger 360 ATX
· 77 Ramcharger 440 ATX
