Posts: 14 |
I have a 98.5 Contour SE V6 with a very noticable rattle coming from the rear of the car when I drive over a rough patch of road.It sounds exactly like something is loose in the trunk but nothing is loose. The car's performance is excellent, but this noise is becoming embarrasing and I worry that it could be something serious. Has anyone experienced a similar problem? If so, what caused it.
Posts: 99 |
I have a similar problem on my 98 4cyl. I haven't had time to look into it to much yet though. Sounds like its something in my suyspension, but everything looks alright. I'll have to look at it some more. Anyone have a suggestion on where to start?
Posts: 332 |
I have a relatively loud and consistent rattle coming from the rear driver-side of the cabin. I stopped worrying about it when I realized it was something in the seatbelt mechanism. I figured it would be too costly to address.
Black E1
Posts: 14 |
I have a visit with a mechanic this weekend. I will post here what I find out.
Posts: 974 |
Bryan, thanks for post! I have the same problem and will sooner or later get it looked at! Please let us know. Ford will try to soak you for new springs/ shocks. But this has been only a temperary fix for some. A ford rep told me that they don't even have a fix, for whatever the problem is.
2001 Cavalier 150-175 more kms per tank of same size Pioneer 12 CD Changer
SOLD Green 98 Mystique GS Sport Zetec ,ATX 885 Fogs mod. Hi beam mod. 205 15s
Posts: 14 |
My mechanic was not able to road test my car but he did put it on a hoist. He noticed that the muffler made a rattling sound when he hit it with a rubber hammer. Also, he noticed the rear struts were getting soft but nothing serious.I used to have a Camry which needed its struts changed as often as its oil, but they never made a sound. Anyway, I am going for a road test this weekend and you can be sure it will not be with a Ford dealer mechanic.
Posts: 75 |
Hey guys,
About 2 months ago I lifted my car up because of the same problem, but what I found was that my sway-bar links were shot. Just a suggestion, but for me the noise is gone.
Scott
1995 Mystique 2.5L V.6 DOHC MTX Magnaflow Exhaust, KKM, Ford Motorsport 9mm Wires 135,000mi on car/ 40,000 on engine I'm a tech in a Ford garage and I hate working on these things, but I love my car.
Posts: 14 |
After my mechanic test drove my car on the weekend, I have made an appointment to have the rear sway bar bushings replaced.It is not an expensive job. It is interesting that when he phoned the Ford dealer to see if they had the part, the dealer said they had lots of them!
Posts: 219 |
Scott
How can you tell if the links are shot? As you can see, not all that experienced, but eager to learn.
Bryan,
What did the total come to?
- Zack
1995 Contour LX 2.5L V6 MTX 150,000 miles and still going strong PIAA 510's (Finally I can see again!)
"It isn't pollution that's harming the environment. It's the impurities in our air and water that are doing it." George W. Bush
Posts: 14 |
