#445940 09/26/02 01:15 PM
SVTCAN Offline OP
I've noticed that when filling overfilling the gas the needle does not pass the "F" mark. No matter how much I overfill it. My old Contour, Mustang and the loner Explorer does go over the "F" mark. Is this normal on the SVT?
#445941 09/26/02 01:21 PM
I am Canuckian
I am Canuckian
Don't know if it is normal, but from what i've read you shouldn't over fill the fuel system as it prematurely gunks up the pcv system.
Green 96 mystique gs 4cyl mtx 16.9 in the 1/4 mile @102500 miles 95SE in Midnight Red MTX MSDS headers and y-pipe SVT exhaust SVT UIM Optimized se TB. Full pre 98 SVT body kit 15.741 @ 87.73mph :)
#445942 09/27/02 04:27 AM
My SVT goes a little past the "F" mark when full, and it usually stays there for the first 1/6th of the tank or so.
1998.5 SVT Contour - Black H&R's Optimized Y-pipe and TB Open element intake w/heat shield 18x8 Mas Italy Axels (40 offset) w/225/40/18 2x Kicker 8" midbass "subs" in rear deck (infinite baffle setup) A few more little things...(like bushings)
#445943 09/28/02 11:49 PM
I don't think those gauges are that accurate anyway. Do you notice that it goes down a lot faster when you're about mid tank? Then it hits below red when you have 2-3 gallons left?
#445944 09/29/02 12:42 AM
i usually get around 300Km on the first half... then only 200Km on the second.
96 Mystique Spree Duratec ATX
#445945 09/29/02 07:39 AM
I am Canuckian
I am Canuckian
The guages in both my cars are different in behaviour. They both indicate at different speeds. You kinda gotta learn how to read it. I think that probably goes for most cars though.
Moderated by  Gerald_dup1, mbb41_dup1
