I wouldnt reccomend high power altenators, fried my HU in my 84 Topaz.
Tried the 2 battery thing, worked for awhile, then it was the same thing. 2 batteries will help as long as you drive around for awhile with your stereo off to charge both batteries, then turn your stereo on. Your altenator is still putting out the same amount of amps, but now it's only sending half to each battery.
If you do this make sure you go with a good brand. I also did this in my Topaz and it drew current either way, so if I unhooked the battery in the front, the car would still turnover becuase of the battery in the back.
And even if you do both, while your systems not on full blast you still run the risk of frying something.
Caps come in different sizes depending on your needs.
1 farad is equal to 1000 watts. they have .5,1,1.5,2 and probably higher, Are you really going to be running more than 2000 watts through your system?
Caps are made just for the purpose of storing energy for your stereo system.
This is my .02 from my past experiences.
If you are looking for something like that high powered altenator try
JCWhitney's, they usually carry items like that, thats where I bought the kit for the second battery.
