Posts: 10,015 |
My guess is a bored 3L. A stroker is also a possibilty, but the cost of creating a new crank is high, unless, the machined down the main journals further from the centerline of the crank to create a longer stroke, but then that woiuld reduce the bearing diamter and would require really thick bearings toi fit in the stock conrods.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 2,039 |
Hmm, considering the 3.0 block from SHO Shop is $2k, expect the 3.5L to be twice as much - $4k, thanks, but no thanks.
I'll stick w/ the 3.0.
-John
'98 4Runner
Posts: 2,517 |
My 3.0L IS about $4k...  But it'll be bad....
Redneck Troll
Redneck Troll
Posts: 2,621 |
http://www.bnmotorsports.com
Posts: 2,676 |
yes, it'll be 4k, but THAT's MORE RELIABLE AND CHEAPER than a TURBO (given that it'll generate less heat), and it's NA, and a heck of a lot more torque and less heat than a s/c as well, so, that 4k goes a long, way, save for the 2k you'll spend on installing it. . .
and yeah, I'm with lance, they're probably borin' the hell out of the 3L. . .
AND, power wise, it should match up right with the turbo and s/c at the flywheel in terms of hp. . .
Posts: 6,760 |
hold your horses. They tried this with the SHO and did the 3.6, granted it was bored and STROKED, so the 3.5 maybe more reliable, but i doubt it. Originally posted by ssmumich00: yes, it'll be 4k, but THAT's MORE RELIABLE AND CHEAPER than a TURBO (given that it'll generate less heat), and it's NA, and a heck of a lot more torque and less heat than a s/c as well, so, that 4k goes a long, way, save for the 2k you'll spend on installing it. . .
Ryan
Trollin!
Posts: 1,469 |
Originally posted by Terry Haines: Oversize liners & pistons in a 3.0 block ......
Wow...I thought the 3.0L liners were already siamezed...can they go bigger bore??
1999 Amazon Green SVT Contour (#554/2760)
"People demand freedom of speech as a compensation for the freedom of thought which they seldom use."
-Soren Kierkegaard (as posted by Jato)
Redneck Troll
Redneck Troll
Posts: 2,621 |
Nope, they're not... and yes, they can. Stock spacing of 4.0157 inches center to center shown here. With a 3.504 inch bore, that leaves just over a half an inch between the two. The liners themselves are about an 1/8th of an inch FYI.
Posts: 6,760 |
maybe a stupid question...but how much would it be to make our own 3.5L then (assuming you already have the block)
Ryan
Trollin!
Posts: 1,469 |
Well..it will be liner to liner at 3.5L I think.. Then, the 3L heads will be raising compression like 2.5 heads on a 3L. And will they put in custom 37mm valves?? Modified cam profiles..if they got 229FWHP with the 3L then about 267 FWHP (320 HP crank) with similarly prepped 3.5L..
