tthomas Offline OP
I am trying to replace my temperature gauge SENDER on my Zetec. Its just very hard to get to! Its on the bottom of the thermostat housing and I'd be damned if I know of a way to get it off.... the Haynes manual isn't being very helpful.
Has anyone done this before and can give me some hints????
Thank you!
Tom
H
H
I'm not familiar with Zetec but I didn't think it was under thermstat housing, are you sure you've got the correct sensor? What color are the 2 wires going to it? Year of car?
Usually after removing electrical connector you just use a wrench on the hex part of sensor. V6 has 2 sensors, one for guage, one for PCM. Zetec I believe has only one that serves both purposes.
My '97 Zetec has two too. All you need is a very large metric wrench (19 ? 22 ? don't remember) or a good adjustable one. Careful on the limestone (is it called that?) deposits on the threads and try not to break the sensor like I did.
FYI, both Autozone and the $tealer sold me the OTHER
one when my gauge sensor went south. Either my car is very special or there's a part # messup somewhere.
The gauge sensor is the one facing downwards, IIRC, anyway easy to figure out.
Tiv
