#443767 09/23/02 11:19 PM
9
94ex Offline OP
My check engine light came on about a day ago, so I took my car to Auto Zone and they said that the O2 sensor needed to be replaced. They asked me if the sensor was before or after the cat and I said before, I think. So today when I was looking in the Haynes Manual it looks like it is before the cat. Is this correct? Also how hard is it to replace the O2 sensor. Anybody have a how-to on how to do such a thing, I looked in the Haynes Manual and there wasn't anyting. If there is something in Haynes what page would it be on? Thanks in advance.
Austin -officially a troll See it here Pro-Flow w/ optimizer STILL for sale
#443768 09/24/02 01:36 AM
Hey!! I just replaced mine - My car is a 4cyl - not sure how much difference - but there are 2 sensors. The pre-cat is right in the front of the engine on the manifold - I needed a slotted socket to fit in there because of the surrounding heat sheild and the wiring gets in the way. You can borrow from AutoZone. The other is on the rear of the manifold near the oil filter. The page in the Haynes manual is 6-15. Good Luck!
-Insperatus - 97'Contour GL
#443769 09/24/02 11:43 AM
Your car has four O2 sensors. Two on each bank. On each bank, there is one before the cat and one after.
If you do a search, you will find plenty of threads on O2 replacement.
#443770 09/24/02 11:34 PM
How many o2's does a 95 SE have? I heard 2 but I'm not sure!
1995 Contour SE K&N Sport exaust -done right Fine Sterio System 215 45 15 Yok H4's CSA 17" 5 Spoke "Concept" Wheels Tinted Glass Blue LED door illumination replacing green bulbs Previous CEG contributions - removed due to absence
#443771 09/25/02 02:56 AM
H
H
'95 v6 has 2 O2 sensors.
'96+ have 4.
