#443583 09/23/02 04:36 PM
E
E
Is there a list somewhere of all of the airbag warning codes for the Contour??
Someone posted that they have a code 12 on the go.
How the heck do you even know it's a code 12, as opposed to say, um, a code RED??
I'm getting a 5-4 or 5-3 flash on occasion, and I am curious as to what it means.
If anyone out there can help and post a list of ALL codes, that would be great.
98 SVT Contour #1702 (silver) - traded in & missed alot! 02 SVT Focus #2686 (blue) - beginning to enjoy the 4-banger.
#443584 09/23/02 09:36 PM
The following is from the Ford TSP (Technical Service Publication):
12=Low Battery Voltage
13=Air Bag Circuit Shorted to Ground
14=Primary Crash Sensor Circuit Shorted to Ground
21=Safing Sensor Not Mounted to Vehicle Properly
22=Safing Sensor Output Shorted to Battery Voltage
23=Safing Sensor Circuit Input Feed/Return Circuit Open
24=Safing Sensor Output Feed/Return Circuit Open
32=Driver Side Air Bag Circuit High Resistance or Open
33=Passenger Side Air Bag Circuit High Resistance or Open
34=Driver Side Air Bag Circuit Low Resistance or Shorted
35=Passenger Side Air Bag Circuit Low Resistance or Shorted
41=RH Primary Crash Sensor Feed/Return Circuit Open
42=LH Primary Crash Sensor Feed/Return Circuit Open
44=RH Primary Crash Sensor Not Mounted to Vehicle Properly
45=LH Primary Crash Sensor Not Mounted to Vehicle Properly
51=Air Bag Diagnostic Monitor Internal Thermal FuseFuse Blown Due to Intermittent Short to Ground
52=Backup Power SupplyVoltage Boost Fault
53=Primary Crash Sensor Circuits Resistance to Ground or Air Bag Diagnostic Fault
