#443448 09/23/02 05:41 AM
I have decided to replace my o2 sensors because they/it is shot. I was wondering if anyone has an easy to understand diagram handy? I could get a Haynes manual but I figured you guys/gals would have some tips the manual wouldn't.
Thanks
Adam
1995 Contour SE K&N Sport exaust -done right Fine Sterio System 215 45 15 Yok H4's CSA 17" 5 Spoke "Concept" Wheels Tinted Glass Blue LED door illumination replacing green bulbs Previous CEG contributions - removed due to absence
Check the FAQ section on Common Problems and find the page on check engine lights for more info to see if you actually need an O2 sensor. If you need to replace them, there is one located on each exhaust manifold on the 95s. Try searching for sensor and you'll find about many peoples experiences changing these. The front one is easy, the back one is hard to reach but not impossible. You can change them both in about an hour.
