Originally posted by jdtower: I'm trying to remove the door latch(power)
Anyone know how to do this?
The following is from the Ford TSP. You might need to get a Chiltons (or Haynes) manual to help you out with diagrams: Front Door Latch Removal and Installation
1. Remove door handle/latch assembly as outlined. 2. Release clip retaining front door latch control cylinder rod (22134) to front door latch (21812). 3. Release clip retaining latch bracket to front door latch. 4. Rotate front door outside door handle (22404) to release front door latch actuating rod (22152) to front door latch. Remove front door latch from front door handle. 5. Remove two screws retaining power door lock actuator (218A42) from front door latch. Remove power door lock actuator. 6. Remove cover from front door latch. 7. CAUTION: Carefully align power door lock actuator to front door latch. Failure to properly align power door lock actuator to front door latch will result in damage to power door lock actuator. Pull front door latch remote control link (21940) from bracket on front door latch. Remove front door latch remote control link. 8. To install, reverse Removal procedure.
96 Contour SE
Duratec V6 24-valve 2.5L ATX
108,000 mi.
Replaced: crankshaft w/ DMD, EGR valve (clogged), EVR, DPFE, PCV valve, evap emissions hose & tube (cracked), window regulator (broken), LH & RH PCV tubes, UIM gasket (leak), ignition coil
