Posts: 956 |
I need input from you guys...... I have a 96 GL 2.0 5 speed. Basically I would like to know what temperature should I read in my gauge in normal city traffic. My goes all the way up to "L" then the fan kicks on and it drops to "M". It is strange !!!! I am afraid of overheating !!!
I was very terrified about that at first. I know overheating is very damaging. I first changed the TST. It didn't help. I then changed the temperature sensor that goes in the TST housing. It still overheats. My mechanic said that my FAN is kicking on very late. How many temperature sensors this ZETEC engine has ?? He told me there must be another one. I don't know ?? Is there another one ???
I've been turning the defrost / AC whenever I am driving in traffic, to avoid overheating. When I do that, the fan kicks on and the temperature drops to "R" or below that. That makes me believe is the FAN sensor problem ( agree ?? )
Any help with temperature sensors / FAN sensors ???? Where should my gauge read in normal city traffic ?? Has anyone passed through that ???
Hi guys,,,, any input is VERY WELCOME !!!
I want to hear from you guys...
Thanks in advance !!!!!!!!!!
BB
bvborges@juno.com
** CT - USA **
* 96 Contour Gl 2.0 5 Speed Manual / Clarion CD Change 8" Subwoofer & Sony Amp (LOUD !!) The Cleanest !!!
* 92 Mazda Protege 5 Speed Manual / 1.8
* 94 Yamaha Virago 535 (better than Viagra !!)
Posts: 2,523 |
I'm afraid I can't give you any answers, but I'm in the same camp. Mine does very similar things. Everytime I think it's going to overheat, the fan kicks in and saves the day...weird
125.2 FWHP - 126.5 FWTQ SVT exhaust (#4 of 9) - B&M FPR - Custom CAI - bnoon optimized TB #1 & 2 (beat that!!) Black '98.5 SE Zetec MTX Best quote seen in a chat - "Jinx 12345678910 you owe me a naked picture of yourself!"
Posts: 956 |
Hi Davis..
Thanks for the reply !!!
Didn't you try to fix the problem ?? Change temperature sensor ???
I don't like my car doing that... I cannot go to a drive thru !!! If I stop my car the temperature goes all the way to "L" and then finally (and late, I believe) the fan Kicks on !!!!
Anyway... just want to collect few inputs and comments !!
thanks Dave !!!
You are just living with it ??
** CT - USA **
Posts: 620 |
My Zetec's temp guage tends to stay nailed at a spot just a bit to the right of center.
('96 GL ATX)
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth " mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip involuntary mods: compression increased after head gasket failure
Posts: 126 |
1996 GL Zetec MTX H & R springs KKM intake Strut braces both front and rear door dingers removed 2.25 inch exhaust side markers 4 point racing harness's soon to have 19's!
Posts: 2,848 |
Mine stays between the A and the L as well, with little change unless it's incredibly cold out. I was told by the dealer it was normal, and 5 years and 92k miles later, it's fine.
1999 Silver Frost SVT #609 of 2760 Born on 12/3/98
KKM Intake Removed Resonator 35% Window Tint all around Tinted Tail Lights ElKy Mesh Grilles HID
Dyno'ed at 175.3HP/155.5TQ
Posts: 2,523 |
Originally posted by TheGreatOne: Mine stays between the A and the L as well, with little change unless it's incredibly cold out. I was told by the dealer it was normal, and 5 years and 92k miles later, it's fine. Same here. That's why I haven't really done anything to it except keep a close eye on it.
Posts: 2,657 |
Originally posted by Paul Kienitz: My Zetec's temp guage tends to stay nailed at a spot just a bit to the right of center.
('96 GL ATX) I'm in the same boat as Paul. I honestly think something is different about my Zetec. Ever since changing to synthetic oil last summer it has never gone past the half way point on the temp gauge. Actually, once warm it tends to sit just BELOW the half way mark. I've even tried to make it run hot but it never seems to budge. I'm not complaining, I love it. I just wish everyone else didn't have the problems. I have no idea what it could be.
Posts: 884 |
Check the archives....perfectly normal. Ford even knows about it.
John
Posts: 974 |
As long as you stay out of the red, have your rad flushed at least every 2 years. There is even a product called "water wetter". I have never tried it, but a couple guys here have tried with a some success. Keep us updated if you do find a better solution.
Oh ya, there was also a post in the zetec forum about a different tempt thermistat!
Hope this helps!
2001 Cavalier 150-175 more kms per tank of same size Pioneer 12 CD Changer
SOLD Green 98 Mystique GS Sport Zetec ,ATX 885 Fogs mod. Hi beam mod. 205 15s
