Page 2 of 2 1 2
BBorges Offline OP
Thanks all of you guys !!!!!!!!!
Nice inputs !!
I guess I don't have to worry... my temperaure in going out of the "normal" range.
thanks again.. and if I could help anyone anyhow just let me know... It would be my pleasure !!!
Thanks
** CT - USA **
* 96 Contour Gl 2.0
5 Speed Manual / Clarion CD Change
8" Subwoofer & Sony Amp (LOUD !!)
The Cleanest !!!
* 92 Mazda Protege
5 Speed Manual / 1.8
* 94 Yamaha Virago 535
(better than Viagra !!)
When I bought my 96' Mystique 4cyl in December it ran between M-A-L, but this forum assured me it was okay. Last March, I was driving and it ran into the red, and did that every time I ran it for more than 15 minutes, the fan when on and off, but did very little. The thermostat, which Midas replaced, was fine, the gauge sensor, was messed up, and was replaced as well. When I got it back it ran in O-R which was fine. Now, two months later, it varies from O-R-M and sometimes A for no apparent reason.
I trust my thermostat is fine, I just think that Ford's gauge sensor is worth recalling (like on the V6).
Kenneth Clark
'96 Mystique
Zetec ATX
All this is caused by bad quality control from ford on the temperature sensors. I've had 4 so far and each one has read differently, thats why ford dont put actual temperatures on the guage
Since fitting an accurate oil temperature guage I can verify that all 4 of my guages that collectively read O, M, A and L when the fan cuts in all result in the same engine oil temp
So dont worry unless it goes higher than normal.
PS so far I have found 3 temperature senders on the Zetec. 1 is above the thermostat, 2 is in the air intake and 3 is a small one down on the lower engine block. All are routed to the EEC unit so it is the computer thats decides the dashboard guage position
Mad Mole
Visit Mad Moles Mondeo Madness
2L Zetec, Cams, Stage 2 head, Valve work, Powerflow, Unichip, AEM Ram, K&N, Ecotek, 75mm Lower etc.
192 BHP, Faster than a speeding Duratec!
BBorges Offline OP
Hi Madmole...
You said there are 3 temperature sensor on the Zetec ?? I changed the one in the thermostat. How can I know each one is the wrong one ??? I really believe I have a bad sensor... my fan is kickin on very late... when the gauge hits the " L " . I don't like it doing that...
** CT - USA **
* 96 Contour Gl 2.0
The Cleanest !!!
* 92 Mazda Protege
I have a 97 Mystique Zetec that runs between the O and R during highway speeds and immediately runs up to the L when sitting in traffic, then the fan cycles on and off repeatedly with the temperature alternating between the L and A. I have had the car to three different dealer garages and they all told me that this is NORMAL for these cars. I believe that this has been discussed at length many times on this forum.
BBorges Offline OP
I guess you are right Mysty....
If it is under NORMAL it is normal !!!
But still, I'll kept my defrost running on traffic !! :p smile
Thank you for the comment !!!!!!!!
** CT - USA **
* 96 Contour Gl 2.0
The Cleanest !!!
* 92 Mazda Protege
Page 2 of 2 1 2
