Posts: 1,053 |
When you guys talk about temp guages, are you talking about coolant temp or engine temp guages ??
My temp reading has started to read low (N-O)in the last 10 days. Heat works fine as does AC.
Thanks in advance...Mark
'98 Mystique LS V6 MTX
"Unprofessional driver, wide open course." #9 - Hitting .400 for ever "Wake up the damn Bambino; I'll drill him in the ass." -- Pedro Martinez "The MTX75 was not designed to be a drag racing transmission" -- Terry Haines
Posts: 304 |
I can count at least 20 Mondeo's here in England who began to read low just before pump failure and meltdown, noth Zetec and Duratec
I believe (and this is pure conjecture) that as more of the impellor blade vanishes that the flow slows down in the engine leading to hot and cool spots. I think the sensor is a cool spot as it picks up the air flowing over the radiator and is a large metal chunk and hence has some cooling ability of its own. Of course when the last bit of impellor goes then there is no circulation and meltdownm follows very rapidlly.
The differences in peoples temperature readings is due to the poor quality control on the senders. I have hadd 4 different sendors and all 4 read at a different part of normal. Anything from N to L can be OK. Its above or below, normal temps you need to spot, but of course you need to know what is normal for your car.
I now have accurate Oil and water temperature guages tapped into my engine for more accurate monitoring. Currently My fan comes on at exactly 101 deg C, the thermostat opens at 92 and my engine will sit between 85 (Motorway at high speed) and 101 (London Traffic). I have an Oil cooler fitted as well just top make sure.
Mad Mole Visit Mad Moles Mondeo Madness 2L Zetec, Cams, Stage 2 head, Valve work, Powerflow, Unichip, AEM Ram, K&N, Ecotek, 75mm Lower etc. 192 BHP, Faster than a speeding Duratec!
Posts: 974 |
Car has been fine for a long time and I'll get the thermistat replaced as a garage said that it is the problem. Thanks for advice!
2001 Cavalier 150-175 more kms per tank of same size Pioneer 12 CD Changer
SOLD Green 98 Mystique GS Sport Zetec ,ATX 885 Fogs mod. Hi beam mod. 205 15s
