Page 3 of 4 1 2 3 4
#441261 09/20/02 06:14 PM
Originally posted by ssmumich00:
Just go Amsoil full synthetic 5W-30 with an Amsoil SDF-11 filter
BUT only if you like high amounts of viscocity index improvers which are not good for your engine; especially high revving ones! Mobil 1 5W30 uses NO V.I. Improvers... Yet another reason why I chose Mobil 1 over AMSOil.
#441262 09/20/02 10:15 PM
fine particulates get past the air filter, into the UIM, LIM, air mixes in combustion chamber, blah, blah, blah, oil is circulated there to lubricate and cool, you get DIRTY oil. . . otherwise we wouldn't need to change oil that regularly, except for the heat break down, etc.
Suneil
#441263 09/21/02 09:55 PM
Demon, definately not so. To make claims is quite different from living it. I've been driving my SVT w/AMsoil 0w30 Full Synthetic Racing Oil as mentioned in the DMD topic for most of my now 53,000 miles. I've put on, I can pretty much guarantee this, more real racing miles than most any CEG'er or Contour owner around and If people claim such catastrophy in high rpms with our motors it's quite strange that an oil with such viscosity improvers has kept my motor running strong, even under the CLAIMED high stresses put on by an UnderDrive Pulley.
As I said in the DMD topic, AMSOIL, AMSOIL, AMSOIL!!!
Greg by the way, Mobil 1 had significantly worse wear than even Castrol Syntec on a 4-Ball Wear Test, Mobil 1 Tri-Synthetic 0w30: .607....Castrol Syntec 5w30: .576....But none of the popular synthetics could compare to Amsoil Series 2000 0w30: .373 (the smaller the wear scar the better, so the lower the number the better). Tests were done at 40kg Pressure @150deg.C, 1800rpm for 1hr duration. A professor at the Universtiy of Hawaii did tests on many synthetics, there wear and breakdown properties and Amsoil along with Synergyn came up at the top.
PERFORMANCE PARTS for the TOUR click here:PXRACING Homepage email:pxracing@aol.com
#441264 09/21/02 10:03 PM
Micah,
What's the difference then between AMsoil 5W-30 and the 0W-30 you run? I don't solo or anything like you, so 5W-30 synthetic from them should be fine, right??
Is it better to switch to racing oil like you?? It's not THAT much more than what I already pay for the AMOSIL.
Suneil
#441265 09/22/02 01:51 AM
O
O
for over 50years marvel mystery oil have been added to
billions of cars and still counting.I,ll stay with
marvel and kendal 5w30.Also try this!freeze your oil
and see which one flows better!Its the cold weather
start ups which cause engine damage.
New Pics of OUTKAST 1!Sept2006
#441266 09/22/02 02:59 AM
I don't know if anyone has time to read this but it has some good info,
http://www.nightrider.com/biketech/oilinfo1.htm
'98 Black/Blue CSVT -#162 D.O.B 4/12/97- -----Many MODS-----
#441267 09/22/02 03:03 AM
If you found the last artical help full here one on oil filters
http://minimopar.net/oilfilterstudy.html
Mat
#441268 09/22/02 04:08 AM
My owners manual says to use 5W-30 and the Motorcraft site says 5W-20...
"Cobb - It's not just for corn anymore!"
#441269 09/22/02 04:34 AM
Ford revised it to improve their CAFE rating (emissions). You can use either. I use 5w-30 because it's available in synthetic formulation (Mobil 1)
E0 SVT, lightly modded
#441270 09/22/02 06:09 AM
I like the fact that Mobil1 has no ash content... amsoil has very small amount, but it's there nontheless...for money and availabilty, mobil1 is just fineeee.
Page 3 of 4 1 2 3 4
