Page 2 of 2 1 2
Check out this too.
-Colter
My Car
the dealer told me only the 99 & 2000 contours were glued in i know my 1997 had screws holding also. wish they would have s
stuck with something that worked
1999 SE Sport
2.5 atx
Originally posted by golof:
i was curious about this problem so i went out and took at look at my dash...mine is not glued down...but it has screws in it..did it come like this from the factory or did someone just do it as a fix? (95 GL duratec)
The 95's are fine. Getting screwed here is probably good.
The problem seems confined to 99-00 Contours-Mystiques. The dash in my 2000 SVT is different from the dash in my 98 (the 98 had a screwed on piece inside the glovebox covering the edge). The changes are very subtle, but real.
P.M. Summer -- simul justus et peccator
2000 SVTour Silver Frost 374/2150 -- #9669 of 11445 total run
Blaupunkt Heidelberg with A08 Changer and RC-09 remote, Boston Acoustics, K&N, Mobil 1 and Cobra R Mobil 1 "Factory Fill" plate, 35% metallicized tint, high beams in the lows, Bill Jenkins' "off color" floor mats, and custom "koozie" cupholder (pics soon!)
96 Sable ZZZ (wife's)
Historic Ownership:
42 Dodge Powerwagon Munitions Carrier, 59 Morris Minor, 64 TBird, 69 BMW 2002 Blue Dot, 72 German Ford Mk I Capri V6, 76 Honda Accord, 82 VW Scirocco, 88 VW Jetta, 91 Ford Escort GT, 98 Countour SE Sport V6 ATX
Cars I want:
Lotus Elan S2, Austin Healy Sprite Mk I, my old BMW 2002 back.
If you think this sig is long, you oughta see my undergraduate transcripts!
I was driving the other day with my contour, and have had no previous dash problems, and I hit a speed bump at a "medium" speed which is when my defroster popped right out, is this caused by the dash warping? if so, how can I tell? It seems to be coming apart from the window, but not too much. I tried snapping it back into place but failed miserably... Please Help!
1999 SE Sport
ATX, Red, 2.5l v6
Eats ricers for breakfast smile
Currently No mods
yes...take it to your dealer and they'll repair or replace for free laugh
-neal
99 SVT...modified
96 GL....the beater
"I live my life a quarter mile at a time. For those 14 to 15 seconds, 16 if I get tire spin, or get a bad jump, or possibly if I have a friend in the car, I'm free."
The dealer tried telling me it wasn't a common problem(lol) last year but replaced it no problem! I'm still waiting for this one to do the same
'69 Chevelle SS
'99 Mystaque GS
there is a RECALL for any 99+ contours with dash warpage/problems...due to the gluee..
had mine replaced already under the recall
eric
First I would like to congratulate my 2002 "The Perfect Storm" undefeated National Champions MIAMI HURRICANES*1999 Ford Contour SVT #206 00 SVT motor with Return fuel*Black-Tan*Cold Air Intake with 6" S&B Funnel Ram*Sho-shop off road y*Brullen Cat-Back 3.5" slant tips no res*Unorthodox racing crank pulley*Lotec Guage pod with Air/Fuel, Oil Pressure and Voltage*17" Image Tuners*215/40 Falken Ziex's*
B/M Short Shifter*Nokya 9006/9005 80w/100w Xenon's*JSP wing*BNM White Faced HVAC*Custom svt emblemed rear*Bosch +4's*H/R springs*Euro Sidemarkers.
Eric@ritterpenusa.com Centerforce Dual Friction Clutch and Fidanza Flywheel.
E
E
I got the recall notice.. Sez they will "look at it" and glue it OR replace it. The free recall is good for one year from the date of the letter.... So mine is up about a half-inch at the pass side defrost and rattles... Prolly around Jan I will ask for fix... (I DO worry about my "pushed closer to the dash steering wheel being a compication?? in dash replacement?? anybody have a clue if it really will be a problem? It's moved about 2" closer to the dash.
One beat'99 Tropic Green SVT
Page 2 of 2 1 2
