i have a 99 SE, my dash is coming unglued, i took it to ford and they said they will fix it by reglueing and will charge me $165, which is gay since my car has only 41k on it, who else has had this problem... i think i may call customer service and say wasssssssup... confused
1999 T-Red Contour SE Sport
The dash in my 99 SVT was replaced last summer under warranty for that problem and the dash on my wife's 99se will be replaced this summer for same thing.
The problem is that dashboard is defective and I've heard glueing it will only postpone the inevitable.
Good luck!
Brian
'99 SVT Blk/mid blue
#2414 7/30/99 (a Friday car)
'99 SE (Wife's)
Where on the dash are you having this problem? I think I might have to go outside and give mine a good once over. I never noticed anything coming undone but if so, I've got 40k on mine also. hmm.... I hate little things like this... mad
-Dan
1998.5 SVT "Black and Blue" #5292
See here for MOD list.
"Washing your car to make it rain does not work."
look at your defrost vent, see if it looks like its going to pop up, and look for bubbling around it....
1
1
99 SVT Contour
02 Protege5
mine is broken, but the dealer has yet to order me a new one. waitnig to hear if Ford is buying it back as a lemon. i'll keep you posted.
'00 T-red SVT
'89 Dodge Raider
'01 Isuzu VX
Z
Z
Mine certainly sounds like it's falling apart... damned rattletrap. :rolleyes:
what can we do about this? I do have Ford extended warrantee on my 98 E0 SVT.
-zero
-1998 Ford Contour SVT E0
BLACK and beautiful, bone stock
-1993 Mitsubishi Eclipse GSX
2.0 dohc I4t 5m/awd, not bone stock
-1993 Pontiac Grand Am GT
2.3 dohc I4 Quad 4 HO 5m/fwd, beater
mine is loose up by the windshield & also the vents are popping up i talked to dealer they said they would have to replace the whole dash because if they glue it. it will just keep doing it. really ticks me off the car only has 15k on it. and i dont like the thought of them ripping my dash cover off and then trying to glue it back on. if it didnt work new. and it sounds like most are falling apart. i dont think it will fix it. mad
1999 SE Sport
2.5 atx
i was curious about this problem so i went out and took at look at my dash...mine is not glued down...but it has screws in it..did it come like this from the factory or did someone just do it as a fix? (95 GL duratec)
Sounds like someone "Jerry rigged" it.
:rolleyes:
-Colter
My Car
