#440875 09/19/02 12:30 AM
1
1
Went to my local Autozone and they came up with this code. Excessive exhaust emissions, so on and so forth. The guy said it could be anything, so he suggested in not starting at replacing the EGR valve. Has anyone come up with this code and a fix? The car runs fine although gas MPG is somewhat bad.
Thanks!
#440876 09/19/02 12:41 AM
Derek Scion xB 5-spd Previous: 2000 Silver Frost SVT Please share the road with cyclists.
#440877 09/19/02 02:02 AM
P0402=Exhaust Gas Recirculation (EGR) flow excess detected
Possible causes:
-- EGR valve stuck open.
-- EGR vacuum regulator (EGR V.R.) solenoid vent plugged or iced.
-- EVR circuit shorted to GND.
-- EVR circuit shorted to VREF.
-- Pinched/iced pressure hoses.
-- Improper vacuum hose connection.
-- Plugged/pinched EGR V.R. vacuum hose.
-- Plugged EGR tube.
-- Damaged EGR V.R. solenoid.
-- Damaged Differential Pressure Feedback EGR (D.P.F. EGR) sensor.
-- Damaged PCM.
