Yes and no.
The turbo is rpm dependent in that you must have a motor that spins/runs to make exhaust, but that is about it. Exhaust volume/cylinder does not change a whole lot as rpm goes up, but the total volume/time does go up as rpm goes up since there are more strokes at higher rpm.
That is irrelevant in the case of the turbo's dependency upon it.
Let me ask you this, if the throttle is full open and the engine is at 1000 rpm or at 7000 rpm: Is there a significant diference in the exhaust volume that one cylinder can produce at either rpm if time is not a factor?
Think of it this way...you can size the turbo to provide boost at a low rpm, and then as the rpm climbs you can regulate the portion of the air that is put into the engine with a wastegate. This is why turbos are called 'free' power.
I don't want this to sound condescending, but if you understand what Rara is talking about then you will understand why aside from cost, the turbo is a far superior option to the centrifugal force supercharger. It translates in a torque boost all throughout the usable rpm range of the motor and not just at the top of the rpm range as with the vortech.
On the other hand, any boost is better than no boost!
warmonger
